Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you fix a cracked screen on a sony bravia 32 inch
Anonymous
Level 2:
  • Expert 189 Answers
  • Posted on Oct 20, 2009
Anonymous
Expert
Level 2:
Answers
189
Questions
Helped
62887
Points
580
HELLO
The answer is simple to this one....NO!
This is the main problem with LCD TV's when the screen is cracked a replacement screen will cost more than a new set.
Your only cure is a new TV!
4 Related Answers
Anthony Gonzales
  • 267 Answers
  • Posted on Jan 30, 2009
SOURCE: horizontal line in middle of screen
IF THIS IS AN LCD SET, YOU NEED TO GET IT SERVICED. YOU HAVE A BAD LVDS CABLE OR A BAD PANEL. HOPE IT'S UNDER WARRANTY OR A SERVICE CONTRACT.
Anonymous
  • 43 Answers
  • Posted on Jan 05, 2008
SOURCE: MY SONY BRAVIA 32" CRACKED LCD
Unfortunately in most cases the cost to repair the tv is not worth it. The replacement panel plus the labor in most cases cost's more than what the tv cost you to buy. You can call Sony if you are intrested in the cost of the panel. 1-800-222-7669
Good Luck
Anonymous
  • 10594 Answers
  • Posted on Oct 06, 2009
SOURCE: i have a sony bravia xbr 32 inch and the picture
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Anonymous
  • 52 Answers
  • Posted on Nov 14, 2009
SOURCE: sony bravia kld32s4000 32 inch lcd vertical lines
Bad LCD panel if still under warranty have TV service if not you need to replace the panel.
1helpful
My screen is cracked on my 32 inch sony bravia.is there a replacement scrren i can buy
Replacement panels are available for purchase, but in most cases it will cost more to replace the screen Vs. buying a new set.
Cracked tv screen
You cannot fix a cracked screen, replacement is the only option. The problem is that it will be cheaper to replace the set vs. replacing the screen.
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
2answers
I have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
i have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
2answers
I have a sony bravia xbr 32 inch and the picture is only on half the screen
Thanks.
3helpful
2answers
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
