Question about Onkyo TX-SR705 Receiver
Receiver turns off when volume is high
Onkyo receiver turns off when volume is turned up past medium. Had the receiver for 5 years and never had a problem until recently.
    Guru:
  • 449 Answers
The regulator is bad.
Posted on Oct 20, 2009
Anonymous
SOURCE:
The volume control only goes up to +18 on my onkyo t sv919thx. can't hear it
Sounds like the volume controller is faulty. Did you use the master volume knob on the front to increase the power rather than the remote?
Here is your manual. It sure is a complicated piece of kit. They have three service centres on the last page.
https://www.de.onkyo.com/downloads/2/6/5/5/3/Manual_TX-SV919THX_En.pdf
Dec 30, 2016 | Onkyo Audio Players & Recorders
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
Jan 07, 2015 | Onkyo Tx-sr507 A/V Receiver
I turned on my receiver and I do not get any sound, unless I crank up to max and then I get faint audio. The same when I use the head phone jack
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Aug 07, 2011 | Onkyo Audio Players & Recorders
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
Apr 09, 2011 | Onkyo TX-910 Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Onkyo tx 906 amp
1) I bought the same Onkyo model from goodwill a couple years ago and it had the same problem. The solution is simple: Get yourself some Deoxit D5. This is a spray that will clean out all the oxidation in the volume pot. To do this you'll need to remove the cover of the receiver. Deoxit can be bought at guitar shops, or if you know a musician they might be willing to do it for you.
2) User manual is available for download, for free. Google "Onkyo tx-906 receiver manual".
Mar 17, 2009 | Onkyo TX-DS575 Receiver
Onkyo htr 330 universal remote codes
I have the HT-R570 Receiver and here's what I ended up doing to use the Verizon FIOS DVR remote to turn the receiver on and off with volume control. Know that Onkyo uses 2 codes 1 for on and 1 for off so use the AUX for ON with Volume control and the DVD for OFF. (I rarely use my DVD and when I do I use the DVD remote that came with the DVD)
Use the AUX and codes 1347 or 1558 to turn the receiver on with volume control. Press AUX and OK together and release. Enter the code. it should now turn the receiver ON with volume control.
To use the DVD button to turn the Receiver OFF, you have to use the search method to capture the code. Tried every code I could find on the internet and their is no universal code for OFF and ON.) With the receiver ON, push down DVD and OK together and release (should get 2 flashes of all component keys) enter 922 and with remote pointing at the receiver press the >" (forward/pause button) then press and release the >> (fast forward button) until the receiver turns off. If you go too fast and go past it, quickly turn receiver back on (within 20 seconds) and press-release the <<(backwards button) slowly until it turns off again. Then press the OK button to store the OFF code in the DVD function button. Any questions...E-Mail me at [email protected] Lots of Luck!
Nov 30, 2008 | Onkyo HTR500 Receiver
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
Onkyo TX-SR705 Receiver Logo
223 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
