Question about Sumvision Audio Players & Recorders
Sumvision Cyclone Media Player - how do I get subtitles to show? Subtitles files are .SRT or .SUB and named same as the avi/divx/xvid file The remote subtitles button does not seem to do it.
Posted by naresh_tanna on
Anonymous
    New Friend:
Hi
i have sumvision cyclone multimedia player. its not reading any files when im connecting to tv but works fine with usb
Posted on Apr 28, 2010
2answers
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
1helpful
2answers
I have a serious problem...i wont to see movies with greek subtitles and every time i put the srt file in my movie file (avi,divx etc...) it seems that its added but when the characters starts speaking,the...
Firstly i am not able to understand your problem correctly.What i think your problem i am writing solution according to that.
Try playing in different player or better player like vlc which can play all types of media files.
May be there is some problem in your player caching.As caching needed everytime u play a movie.Try uninstalling your player then reinstalling.
Hoping this will work
50helpful
5answers
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
1helpful
Hello, I'm trying to display Arabic srt subtitles ...
If you have Arabic lang. in your windows, and you have the movie (.avi) and the subtitle (.srt) in the same folder with exactly the same name for both 2 files, and you use VLC as media player .. then:
1-Download (Subtitle Edit 2.9.3) software .. it's free!.
2-after setup .. open the subtitle (.srt file ) and adjust "defult file encoding" (same window-left side) to: UNICODE
4- Save (from file tab).
5- You can also adjust the time (later or earlier).
In case you have any questions, my e-mail:
[email protected]
Enjoy..Regards
Ahmed Hosny [Egypt]
1helpful
Can´t see subtitles
Open the .srt file with wordpad and save as a .txt file. Now it will show the subtitles.
2helpful
2answers
Can't get English subtitles on
Check the language settings on the DVD player. I'm not familiar with Panasonic machines, but most players have default language options for subtitles, soundtrack & menus.
The firmware update may have reset this option.
2answers
Divx subtitle problem
i did too have the same problem & i call back ther service center , he told me only the original movies with the orignal sub titles that can be played
How i can view divx whit subtitles (.srt, .sub.ssa)?
Look for firmware upgrades in Samsung's website.
You have to download a set of files, burn them on to a CD or DVD (check the help file in the download) and then insert the CD or DVD to your DVD Player and follow the on-screen instructions. It is really simple, just make sure you download the correct upgrade from the website. And one advice, use a RW DVD or RW CD because you may have to try it many times ;) .
6helpful
2answers
Divx greek subtitles
look in the menu and try to change the encoding, There should be 3 options, Unicode, Cyrilic & Greek. Select greek if the .sub or .srt file is in ANSI encoding, or select Unicode if the file is in UTF-8 or Unicode encoding.
To find out the encoding of an .srt file the simpliest thing to do is open them with notepad and got to "File" -> "Save as", The encoding should appear in the bottom of the dialog.
2helpful
2answers
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Top Sumvision Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
