Question about Inland u-Touch Multimedia Keyboard/Mouse Optical 70126
Inland 601781 wireless keyboard stopped working.
Inland 601781 wireless keyboard (2.4 GHZ) stopped working. Batteries are OK. Wireless mouse works, so keyboard is suspect. I tried using different USB port and changing batteries. Is this a known problem with simple fix?
Thanks.
Posted by sahilljd on
mukhtar21 shaikh
    President:
  • 2,022 Answers
Remove the battery of the keyboard and install new one and then press connect button from the keyboard side and the receiver side also.
Posted on Oct 20, 2009
1helpful
Wireless keyboard quit working all of a sudden. Changed batteries, rebooted still won't work. Wireless mouse still works.
DId you receive any drivers to use with the keyboard? If you did, try reinstalling them. If you dont have them, search google for the model of the keyboard you have, and try to download them and install them.
If it doesnt work, the best thing to do is to call the customer service from where you bought your keyboard. They just stop working sometimes for no reason. If you still have warranty, they probably will give you a new keyboard.
1helpful
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
2helpful
NEED INSTRUCTIONS TO ACTIVATE WIRELESS MOUSE AND KEYBOARD FOR INLAND 2.4 GHZ STOCK#70120
find the drivers and instructions for inland wireless keyboard and mouse here: http://www.inlandus.com/driverdl.php?
type the product number 70120 and click search. Download zips and follow instructions.
1helpful
2answers
Purchased an inland wireless mouse and it came with 2 AAA batteries, but I can's find a cavity to place the batteries. Is there an instruction manual?
Yes, they made it really hard to see where the batteries go. You need to slide the solid part of the top away from the two buttons. It takes some force to do this.
2helpful
Wireless multimedia keyboard 1.1 not working. Batteries OK
try pressing the reset switch which is on both the side i. e. side of the keyboard and on the wireless censor
1helpful
Getting wireless keyboard working
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Inland u-Touch Multimedia Keyboard/Mouse Optical 70126 Logo
Top Inland Computers & Internet Experts
Ekse
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
