Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Need new gasket for boiler for syncrony logic
N eed new gasket for boiler for syncrony logic i can fit it myself but where can i buy one
Posted by dai2002llew on
  • Lexie Marsh May 13, 2012
    I think that's what I need also. My machine leaks water out of that area also and down the back of the machine. I found one onhttp://www.gaggiaparts.com/nm05-006-wate...
Ernest R
    President:
  • 1,618 Answers
You can check with wholelattelove or servicesunlimited.
Posted on Oct 21, 2009
Gaggia Syncrony Logic has no power
Check the 2 thermal cutouts located on the side of the boiler
Press to reset
Jan 02, 2013 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony logic loses water pressure. If left unused for an hour or two it only dispenses half the water it should. After this it's ok until not used for a while. Any ideas?
Yes the machine should not be left on for that long, it only takes a few minutes to heat up. It does not have an auto refill if the boiler is low on water.
If it heats up the water in the boiler for over an hour, it is safe to assume, that the water might at some point turn to steam, when you use it for the first time, it flushes out all the steam, and fills the boiler with water.
Feb 20, 2010 | Gaggia Syncrony Logic 74884 Espresso...
The steam wand will only dispense water, and will not steam. What can i do?
Replace the steam boiler, and or check the thermostats and the element on the steam boiler. If those are working fine then the CPU board has failed especially where the power leads to the steam, look for sign of damage on the board.
Dec 03, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
No power to Gaggia Syncrony Logic
Re the Gaggia no power problem, the machine does have a re set button, 2 in fact the boiler unit must be removed and the two reset switches are between the sender units (brown in colour).
After disconecting the power source open the machine (top off)The three alan head screws that retain the boiler (front of the machine) unit must be removed it can be lifted clear to gain access to the bottom of the unit where the reset buttons are.
This will save hundreds of dollars in shipping and service fees.
DIY takes about 10-20 min well worth it.
Take care when doing this opperation 240 volts can kill.
Apr 18, 2009 | Gaggia Syncrony Logic 74884 Espresso...
No Steam, No Coffee!
The steam boiler, might be damaged, or the main board is not sending power to the steam boiler. Open machine and check resistance on steam boiler elements.
The coffee machine trips the electricity when I use it.
Take it to a service agent,it sounds like the boiler is leaking.
Do not use it is unsafe
Mar 28, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
159 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
