Question about Epson Stylus Pro 9800 InkJet Printer
Service Call Error - 00010005 - Epson Stylus Pro 9800 InkJet Printer
Posted by reemee26 on
Joseph Kuzara
    New Friend:
This error 00010005 popped up when I was messing with my Print head for cleaing purposes.when I put the print head back into place the lever mechanism that is attached to the cutter blade detached from itself not allowing the printer to move the print head freely.below is a picture I scanned in from my Quick Reference Guide that shows how the mechanism should be. When I saw this I then realised what had happend and was able to put down the cutter blade to re attach the lever mechanism. After this I did not recieve the service code again and the print head was able to move freely. I hope this helps.
Posted on Feb 02, 2012
  • Joseph Kuzara Feb 02, 2012
    I know this is not your model number but here is a link to the refrence guide sense the pic i scanned is horrible and you can not see it
    http://files.support.epson.com/pdf/pro78...
mukhtar21 shaikh
    President:
  • Epson Master
  • 2,022 Answers
If you can do this follow these steps
Check to make sure the locking bracket and screw have been removed from the print head.
Turn off the printer.
Open the lower cover on the front of the printer and remove the bracket and screw holding the print head in place.
Close the printer cover and turn on the printer.
The Pause light, begins flashing and the printer starts charging the ink delivery system.
Posted on Oct 20, 2009
1 Related Answer
Fabio
  • 400 Answers
SOURCE: whene i start my 9880 it giveme a 00010005 error
Make sure there is nothing blocking the carraige (where the cartridges sit).
If there is nothing blocking it then the printer will have to go to an Epson service centre to be repaired as a part needs replacing.
Posted on Sep 03, 2009
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
Epson 4000
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Aug 17, 2007 | Epson Stylus Pro 4000-PS InkJet Printer
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
Clear counter
How can i remove printer count?
Jul 30, 2013 | Epson Stylus Pro 7600 InkJet Printer
Giving me a Sevice Error 00010005
  • This error means there is a problem with your printers carriage operations
  • Check the carriage and the cartridges.
  • Remove anything that could be in the way of the carriages.
  • Check the cutter cap which if may also be a cause.
Thank you!
Sep 28, 2011 | Office Equipment & Supplies
Error message: Service Call Error 00010005
This code is usually appearing when the carriage for the print cartrige is restricted by any foreing object or by displacement one of the print cartrige that is rubbing on top of the cover,
Open the cover and make sure the carriage is free of anything try to move it manually to see what can cause this blocage Hope this answer your question Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Office Equipment & Supplies
Service Request 00010005
1. The CR Encoder and the T Fence must be free from dust and dirt or any other foreign matters.
2. The CR Timing Belt must be free from any defects and the belt must be in proper tension.
3. The carriage must slide smoothly, free from undue load.
4. Measure the resistance value of the CR Motor. (5.8Ω)
5. Execute encoder checking by “Encoder ”) in the selfdiagnostics menu.
6. All the harness must be connected properly and free from short circuit or broken wire.
7. Check the carriage home position sensor.
Dec 24, 2009 | Epson Stylus Pro 9800 InkJet Printer
Whene i start my 9880 it giveme a 00010005 error call service waht can i do to solve this problem? thank you.
Sep 03, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson Pro 7600 Service required error
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
8,041 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
