LG DVB T HDD/DVD 197 won't play dvd's want error
LG DVB T HDD/DVD 197 won't play dvd's error message can't find disc does not reconise blank discs
Posted by cottonemb on
william bennett
  • 945 Answers
Http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
Posted on Oct 20, 2009
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
I cant play DVDs on my Lg DVD player
See my workaround at http://www.fixya.com/support/t622687-unknown_disc_please_check_disc_again
Jul 10, 2009 | Televison & Video
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Dvd disc not playing
Buy a cleaning disc for about $15.00. If that doesn't work it's time to buy a new one.
Mar 16, 2009 | LG RH1999H DVD Recorder/HDD Recorder
DVD recorder model DBRH 197 will not play zone 1 DVDs, is there a solution for this.
1. Power on
2. Open DVD tray
3. Press HOME
4. Select/choose SETUP
5. Use arrows to move to LOCK icon
6. Press 0000000 (press the number 0 (zero) seven (7) times)
- You get the REGION FREE message
8. Confirm OK
OR
Insert a non compatible dvd disc, when the dvd player spits it out again press 0 seven times and the dvd player will congratulate you on making it regionfree.
Aug 08, 2008 | LG Televison & Video
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
523 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
