Question about HP DESKJET PRINTER, HP OR COMPATIBLE
I have an HP Deskjet D1430 and it is having a spooler problem. It says the printer is offline and when I try to change it,it comes up with error 0x00000005. I tried reloading the printer from the disk and it works briefly then it goes back. I look at open active printers and it looks like it is printing then stops and empties out the active printer screen.
Posted by lynda_macke on
Anonymous
  • 71 Answers
The first step you need to do is .. delete the printer icon from the printers and faxes icon.
then insert the cd and browse to its folders..
then under util > ccc > bin > uninstall_L3.
run this file..
it will uninstall the software completely..
> after that install the software again..
> prefferably go to hp.com .. download the printer software and download it.. and install the software again ..
let me knw if it fix the issue,
Posted on Oct 20, 2009
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
I cleared a paper jam from an HP Deskjet 6122, but now it won't respond to commands from the computer. I've restarted the printer and the computer. Now the print manager just says it's...
First things frist. If the printer is conected with a USB Cable to your computer, try removing and reinserting the usb cable. To make sure that it is properly connected.
You might just have unintentionally got the printer in offline mode. Now follow this steps:
To check if it is offline. 1. Go to devices and printers (7), Printers and Faxes(XP), Printers (Vista) 2. Double click on the printer icon 3. Click the option that says Printer on the upper left corner of the window that pops up.
Th only options that you need checked is the one that says Set as Default Printer. For any other options that has a check mark. Click on them to remove the check mark.
4. Click Start again, on the search box type in services.msc, hit Enter. For XP, CLick Run, and type the same thing and then hit ok. 5. A window should pop up with the list of services for your computer. Look for Print Spooler in that list. 6. Right Click on the Print Spooler and Click Stop. 7. Right Click on the Print Spooler and Click Start.
Restart your computer. Try printing again.
Feb 03, 2011 | HP DeskJet 6122 InkJet Printer
It just started blinking and says the printer is offline
If it says printer is offline, it usually means your printer is not connected to the PC. Blinking printer light means there is a problem with the printer (usually paper jam) or with the ink. Check the ink cartridge. Take the cartridge out and put it back in. Make sure you also check the USB cable that goes from your printer to the PC, take it out and put it back in. Also, try to turn off the printer, take it out of the power outlet for 30 seconds and put it back in. If you have a power strip, don't use it, try plugging it directly to the power outlet on the wall and turn it back on.
Nov 09, 2009 | HP Deskjet D1430 InkJet Printer
HP Deskjet F300 Series Offline
my print is offline, how can I fix?
Jun 08, 2009 | HP Office Equipment & Supplies
My HP Deskjet D1430 won't print in color anymore
Try going to the printers properties page, go to the color tab, and be sure that "print in grayscale" is unchecked....keep me posted...
Mar 10, 2009 | HP Deskjet D1430 InkJet Printer
My HP deskjet D1430 isn't working
Do you have drivers installed for your printer if you do try going into printer setup and print test page if it will not it should give you a fault number so you can check on web for the fault and fix it
Aug 04, 2008 | Computers & Internet
227 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
