Question about Philips 47PFL3603D LCD TV
How do you fix the screen on a Philips tv model number 47PFL3603D
    President:
  • Philips Master
  • 1,779 Answers
If the display is damaged, you can't. If it just has scratches then you should be able to live with that. If it's damaged to the point of the picture is distorted with lines then its time for a new set if that's what you choose, because the display is about as much as a new set.
Posted on Oct 20, 2009
Philips model 47pfl3603d tv comes on then backlight goes off after 3-5 seconds but has audio?/
Main board fault. Contact any service technician, or the authorized service centre for Philips. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 11, 2013 | Philips 47PFL3704D 47 in. LCD TV
Philips flat screen plasma tv 47PFL3603D/27
There is no bulb in any plasma TVs. The fault should be with any circuit boards inside it.
Jun 29, 2013 | Televison & Video
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
I am looking for all replacement fuses in for the 47" model, model # 47PFL3603D/F7
Best thing to do is contact a local tv shop, some fuses are specialized so its best to be sure you are getting the correct values. we sell them for a couple of dollars each.
Oct 30, 2010 | Philips 47PFL3603D LCD TV
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
How do i connect my pc to my tv
Yes it supports PC hook up. You can hook it in four ways using either an S-Video, HDMI or DVI connector.
  1. Connect the PC to your TV using either of the above connectors.
  2. Press MENU on the remote control and FEATURES > MODE SELECTION.
  3. Select PC and press OK to confirm your choice.
  4. If necessary, adjust picture settings.
  5. Set the picture format to Unscaled when using wide-screen PC resolutions.
  6. Press MENU to exit.
Oct 08, 2009 | Philips 47PFL3603D LCD TV
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Philips 47PFL3603D LCD TV Logo
249 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
