I recently viewed a few solutions to a problem that people are having with a flat screen tv's. I seem to be having the same issue with my tv. I am fairly sure that the transformer that connects the "hot" side of my inverter board the the "cold" side is shot. I have a 32" element flx3220f flat screen lcd tv. When i turn it on the power light flashes about 3 times then it goes back into stand by. If you unplug the inverter board from the main control board the tv stays on. you have sound, you can change channels everything works. if i plug the inverter board back into the main board the tv shuts down. I disassembled the tv and, with some jumper wires, was able to manually energize the inverter board. this time the tv stayed lit for about 30 seconds instead of 3 seconds. But then the lcd back light shut off. my question is where can i find an inverter transformer for my TV. the numbers on the transformer are: LTT3PC0XB020 and BCK-35-0466. the number on the board it self is BA71F0F01042 Thanks for your time, Anthony
Flashing screen can be of many causes. The details you have given here is not sufficient to post a solution to your TV's problem. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its
left side bar, or view it in Timeslide option.
Hi I have an old school solution for your problem with your tv. Hit it!!!!! When you turn on your tv, go to it and lightly tap on the middle of the left frame. You should see it affect your screen. Do it until your screen is perfect. Hope it works.
Try the technique on this video if that doesn't work ,replace the board by with another of the same part number.Cheap to buy.Ebay.LCDTV Spares shops online
object in the picture look small,tiny and elongated especially when viewed from certain angles.Worse,the picture seems to have a horinzontal bend towards the bottom of the tv screen
it is due to malfunctioning due to technical defects in TV.
YES
the problem is in vertical output section of your TV.
IT is due to some electrolytic capacitor failure in tv.
if it is replaced by the same value as it is your problem will be solved.
hope this will help.
good luck.
it is a common problem & not major.
