Radiator is overheating changed thermastat still overheating says low on coolant no leaking occurring I think there is an air block or blockage somwhere how do I fix or check to see if there is a blockage
Re: radiator is overheating chaned thermastat still
Water pump is the problem,you will find the the water pump impellor has broken or come loose from the shaft,you going to have to replace the water pump
CAR OVERHEATING FIRST CHECK FOR LOW COOLANT IN THE RADIATOR COOLANT OVERFLOW JUG.IF COOLANT LEVEL IN OVERFLOW JUG LOW REFILL ADD COOLANT BACK TO THE FULL COLD MARK.PUT RADAITOR CAP ON COOLANT OVERFLOW JUG START ENGINE LET IT IDLE UNTIL IT OPERATING TEMPERATURE.MAKE SURE TOP RADIATOR HOSE GETTING HOT WHILE ENGINE WARM UP.IF TOP RADIATOR HOSE DONT GET HOT WHILE ENGINE IDLING YOUR THERMOSTAT COULD BE STUCK CLOSE CAUSING CAR TO OVERHEAT.IF TOP HOSE IS GETTING HOT.CHECK FOR COOLANT LEAKS CHECK TOP RADIATOR HOSE AND BOTTOM RADIATOR HOSE FOR LEAKS.CHECK FOR LEAKS AT THE RADIATOR CORES AND PLASTIC SIDE CONTAINERS.IF ALL IS GOOD ENGINE OVERHEATING WHILE IN A LONG TRAFFIC LINE, COOLANT FANS NOT COMING ON.COULD HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR BLOWN COOLING FAN FUSE OR RELAY.COULD HAVE PCM FAULT.MAKE COOLING FAN ELECTRICAL CONNECTORS AND WIRING NOT DAMAGE OR BROKEN.
There is a slow leak and the radiator is low on fluid
Let the vehicle cool down completely and then check the level in the radiator. I bet its pretty low. Top off the radiator with a 50/50 mix of coolant and water. start the vehicle and let it warm up with out the radiator cap on. Keep adding fluid as necessary. While waiting for it to warm up check around for any abvious coolant leaks. Things like hoses, radiator seams, water pump, water inlet/outlet gaskets. If no leaks are found it may be necessary to pressure test the cooling system and even then it might be a slow leak that only occurs when the vehicle is cold.
If the radiator is full than I would suspect that water pump is no longer working or creating enough flow. If the thermostat where stuck you would still get heat. If the water pump is not circulating coolant than you would get no heat and the car would overheat.
Now that you've eliminated the thermostat, it could be a number of other things. Don't drive the car too far until you've fixed the overheating problem - overheating can destroy an engine.
That split ribbed hose you see is plastic wire loom - it carries and protects electrical wires, and is not the cause of overheating.
1. Low coolant level
2. Radiator hose split/cracked, causing low coolant level.
3. Head Gasket - leaking, causing low coolant level
4. Thermostat - stuck closed (you eliminated this possibility)
5. Radiator cap - worn/damaged
6. Radiator fins - obstructed by debris/cardboard
7. Water Pump belt - missing/broken
8. Heater Core - leaking, causing low coolant level
9. Intake Manifold Gasket - leaking, worn, damaged
10. Radiator Fan Relay - faulty
11. Radiator Fan Blade - broken, missing
12. Radiator Fan Sensor/Switch - faulty
13. Water Pump - leaking, causing low coolant level
14. Radiator Fan Motor - faulty
My primary suspects would be Rad Fan Relay (#10), and
Rad Fan Switch (#12).
YOUR WATER PUMP COULD BE BAD.CHECK TO SEE IF WEEP HOLE LEAKING IS SO REPLACE IT IF NOT.MAKE SURE COOLANT FAN IS WORKING.HAVE RADIATOR SHOP PRESSURIZE COOLANT SYSTEM.TO CHECK FOR LEAKING HEAD GASKET.ALSO HAVE RADIATOR SHOP FLUSH RADIATOR.IF ITS CLOGGED UP.IT WILL CAUSE OVERHEATING PROBLEMS.ALSO MAKE SURE YOUR ENGINE COOLANT MIXTURE 50% WATER 50% ANTIFREEZE.TOO MUCH WATER IN RADIATOR WILL CAUSE OVERHEATING.
If you aren't loosing any antifreeze, you might check to see if the coolant fan on the radiator is coming on. If the thermastat is sticking your radiator hose will be solid to even swellen sometimes. Of course not to mention that if a radiator is over 5 years old, it could be bad, so you may need some things checked futher.
Head gasket blown, leaking exhaust into antifreeze.
Clogged catalytic converter.
Thermostat: If the Van heats up, then feel the upper radiator hose. If it's cold, then your thermostat is closed. Replace thermostat.
Coolant: If low, simply fill with distilled water and coolant. Low levels will let engine over heat.
Radiator: If there are cold-to-the-touch spots on the radiator after it should be warmed up, then a clogged is probably occuring. Have radiator flushed.
Head Gasket: If you smell exhaust fumes in your coolant reservois tank, then you got a blown head gasket.
Cat Converter: Only can be tested if off the car. Or you could try a non-contact thermometer. These are also good to testing cold spot on radiator or if thermostats are open.
Cooling fan: If mechanical it'll be spinning. If electrical, it should come on automatically with the A/C, or when it gets hot.
Water pump: Will be leaking from the front if it needs replaced. On a van, it's a tough job.
