1996 Suzuki VS 1400 Intruder Logo
Posted on Oct 19, 2009
Id like to know if there are anyhop up tips on 1400 like to increace performance
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1364
Points
8
Change air filter to high preformance one or just remove it completely, always use premium fuel, add a can of B12 chemtool everytime you fill up (boosts octane),
I have 1999 Saturn SL1. I use to live sea level then moved to altitude.1400’. As I was driving 60 mph, started to go up a mountain the speed dropped to 40mph, the engine in my poor car sounded like it was...
1400 feet is almost no height a all. You are correct about vehicle engines needing some small adjustments to the amount of fuel entering the engine at high altitude but hardly any correction is needed at 1400 feet - now if it was 1400 metres it would be reasonable to blame altitude as a factor in your car's lack of uphill performance.
My instinct is to suggest there is a problem with your car. 40,000 miles is no guarantee of no problems, it is after all 20 years old so the injector spray patterns could be bad or the catalytic converter could be half blocked, either of which can have a dramatic effect on performance...
The screw on the right side of the motor that you
all that screw does is limit freeplay in the foot shifter. best left to someone with access to a factory service manual
Sep 07, 2014 • Motorcycles
Model 1400-7 will not spray
Hi Elias. Having no spray when you need to clean can be frustrating. I'm sorry you're experiencing difficulty.
We have a terrific FAQ that will help you with the no spray. Here's the link: http://www.bissell.com/FAQDetail.aspx?id=1191&cid=ccsocial
How to tell if i have a blown head gasket
When you say keeps overheating ,I personally would
stop using it within 20 min max & not use until resolved,
even if it meant having it towed home
That said, I suspect & you do as well, that you ruined any
hope of any simple repair
Their is a product called a Combustion Leak Tester
that you put over the radiator or coolant cap.
It have blue fluid & turns yellow if combustion gases are present
That is something a repair shop would buy,not a one time
check by yourself
Then the old pressure test, may ,but not likely so something
Black is who knows what,but not good for sure
Your radiator most likely will have to be replaced vs: cleaned
Let us know the end result,i would like to know about black &
chunky,what it was
Lamar 1400 message "Perform Scheduled
My Lamar 1400 says" L 14 scheduled maintenance" and will not run.
3helpful
2answers
113.2027.4 was gven this rado watch by a friend whatis the value of it if in perfect condition? thanks,ryan.
Brand new men's cost around $1200 - $1500, ladies - $1000 - $1400, depending on materials used. Hard to say about used ones, as it depends on the wear and tear, overall look and performance. Rate me, plz.
Fuji F480 - poor picture quality in low light conditions
try pressing the f button next to the LCD then going to the second option down -that is where you can change your ISO -and either increace your ISO when there is less light, or set your ISO on auto, and have the rest of the camera on auto too
1helpful
This is the second phone and always being asked to speak up. mic diagnostics show that even when you yell the bar does not max out.
Try to increace volume over the phone settings itself. If its already max, then just replace the mic and that's it.
If you need more detail, just let me know.
Best of luck
Gateway performance 1400 motherboard specs
Performance 1400 Memory Specifications Standard Memory 128 MB (removable) Maximum Memory 1.0 GB Memory Expansion 4 sockets (2 banks of 2) Memory Comments PC800 RDRAM RIMMs. RIMMS must be installed in matching pairs. CPU Type 1.4GHz Intel Pentium 4 Model Comments 400MHz FSB, Intel 850 Chipset
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
