Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
8532899 I bought a new Projection Lamp for my 42 sony and my tv wont show a picture it just keeps blinking a red light that say stand by what do i do do i have to reset is there a reset button?
shaun taylor
Level 3:
  • Sony Master 1,527 Answers
  • Posted on Oct 21, 2009
shaun taylor
Sony Master
Level 3:
Answers
1527
Questions
0
Helped
338426
Points
3957
Hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
I have a sony wega 2004 lcd 42" lamp light blinks red when tv is off no pic when tv is on. what does this mean?
This TV is garbage! Finally through mine out in the garbage - replaced the lamp cost from $100-300 - both lamps exploded - replaced optical block twice - lens very distorted - plain old garbage! I will never buy sony products again especially since I paid 4,000 for this tv it was new tech at the time and I was desperate for a tv - sad I am!
Replaced projection lamp and also cleaned out most of the dust inside the tv. will power on but shuts off before picture comes on tgen three red light blinks. please help asap. thank you.
Three red light blinks shows that lamp cover is not properly closed after lamp replacement. Make sure that the lamp cover is in its proper position. Try to reset the lamp cover and turn it on clockwise direction until you heard a click sound of a micro switch activated by the lamp cover, then put the set on..
2helpful
My tv is a sony wega kdf42we655 and i have no picture and no sound and the lamp light keeps flashing
Lamp is dead/ broken in your tv and need to be replaced as lamp light blinks showing that problem.
Lamp replacement procedure is easy and written in user manual.
Buy Sony original lamp for good picture quality and replace it as mentioned in user manual.
Click Sony Support to download user manual free copy, if required.
2helpful
2answers
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Sony tv kf-42we610 tv will not come on and red light blinks three times
Three flashes usually means the lamp cover is not attached securely and the TV has gone into a "stand by" mode, recheck that the lamp,lamp door, and front panel is securely attached.
Good Luck !
6helpful
2answers
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
2helpful
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
1helpful
2answers
REPLACED LAMP WITH XL2400 AS REQUIRED
3 time blink shows that Lamp Cover is not fixed properly. Please check Lamp Cover and make sure its fixed securely.
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
