Hello Cicl, I appreciate your post!
If you have a water leak from under your Frigidaire washer it could be a possible problem with a faulty water hose, water inlet valve, or drain pump. Either one of those components could be causing a drain within your washer. Since it could be any one of these underlying issues I would suggest seeking assistance from a professional technician to get a proper diagnosis and repair. I hope this is helpful. -Matt
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Check for tips on the link below to identify parts and
removal:
If
your washing machine will not fill, only hot or cold will fill or is
slow to fill then read these tips. I have covered many of the things
that can happen in these tips...
Washing
Machine Problems No Water
Washing
Machine Fix Washing Machine No Water
heatman101
