If you are using component cables, make sure all are plugged in on both the back of the tv and the cable box. (component cables will have a red and white audio and red, blue, green video)
If your pictures that have the reddish tint are taken indoors, the tint is likely caused by the lighting. You can set up a 'white balance" adjustment to fix that.
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
TV has 3 CRTs, red, blue, green. Its possible that you have a bad blue or green crt. If that were the case the red would be prevalent and the pic would be reddish. The tv has a picture "level" adjustment that if done correctly could get it looking correct. Its probably best to have a tech. do it since you can make it worse if you do not know what you are doing, also there are high voltages present. Good luck
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
