Question about i-mate JAM Pocket PC
When I start my Imate Jamin 3 color bands appear on the screen & nothing else RED GREEN & BLUE & 0n the top left corner it says IPL 1.00 & just below that its written SPL 2.13.. this problem was going on for the last few days but after a few soft resets it was then starting in the normal mode but today no matter how many times I try I just see these three bands..
Posted by amirtk on
5 Related Answers
Anonymous
SOURCE: I-mate Jamin wion't boot, won't charge, won't do anything.
my imat mobil jack is no working
Posted on Aug 07, 2008
Anonymous
SOURCE: lost of drivers of imate jamin
d9bcb72.gifhi everybody! you are go to windows web page and download activesync 4.5 software .and instal winxp user's.then connect your imate phone via usb cable.automatically identify your phone.. .tryit...enjoy...
Posted on Oct 28, 2008
Anonymous
  • 4 Answers
SOURCE: HERM100 IPL-1.03
http://www.mrvanx.org/thg/index.php?option=com_content&task=view&id=16&Itemid=26
Posted on Nov 12, 2008
Anonymous
SOURCE: imate jamin not turning on and not charging
I had the same problem with my Jamin so sent if off to the technician who informed me the Jarmin's internal circuitry prevents the phone being charged when the battery is under a certain voltage so when you use a plug in charger because the battery has very low power it does not trip a circuit in the Jamin to start the charging process. The only solution to to take the battery out of the unit and charge it with a stand-a-lone charger. Hope this makes sense.
Posted on Nov 27, 2008
Anonymous
SOURCE: how do i reset my imate jamin password.forgot
how do i reset my imate jamin password.forgot password
Posted on Jul 17, 2009
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
My mobile imate jamin align screen plz salution
most probably it would be showing a + sign in the center just keep on tapping in the center of + sign where ever it appears. At first it appears at the center then at the top left, then at the top right, then at bottom right and finally at left bottom, just keep on tapping at the center of + sign, now continue with the setup
1helpful
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
2answers
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
I cant go beyond the red green blue white screem
Everytime I turn on my phone its like that.
Nothing's wrong with your phone dear.
If you think Im not sure well I have the same phone and I've had it for a year. So Im sure nothings wrong. As long as its operating fine its ok. Believe me.
Just a little check...
Can you still use the camara?
Can you beam a photo to another phone using bluetooth? If yes, than NOTHING is wrong.
If you have anymore questions I'll be glad to help. Just comment back and I'll try to answer you ASAP.
Good Luck!
1helpful
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
1helpful
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
i-mate JAM Pocket PC Logo
Top i-mate Computers & Internet Experts
Jax Planet
Jax Planet
Sheldon Dedek
matt
matt
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
