Nikon Coolpix S210 Digital Camera Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Date issue on picture
I took a picture and now it has the date on it. I turned the date function off. However the one that I took has the date on it and I need to delete the date from the photo so I can print it.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Oct 19, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200578
Points
38521
You'll need to use a photo editing program like Photoshop Elements to erase the date. Is the date close enough to the edge that you can crop it out?
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
95helpful
3answers
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
1helpful
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
How do I GET DATE AND REGULAR TIME, NOT MILITAY TIME, ON PICTURES
Turn camera ON
Scrol with Menu Burtton to time and date .
Scroll far right and set time and date.
When taking pictures put on the Beach or Snow mode.
Vitally
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
3answers
Canon sd750 ixus 75
i'm using the canon sd750 and I can not set up the date in the photos when I take it. I want to have the date on the picture I took. I search in the menu there's a date stamp function but i can not turn it on. can you help me on this issue, how can i set up the date in the picture?
would you please send it to my email: [email protected] or [email protected]
thank you very much
27helpful
3answers
Date stamp
To get the date/time to be on your photos while taking the picture so you don't have to use the software later do this:
When in the mode to take pictures, press the round "Function Set" button and change the recording pixels to "Postcard 1600 X 1200". "Postcard" is the only setting that will allow the time/date stamp to be recorded on the picture.
Then press the "Menu" button and scroll down to "Date Stamp". You can select "Date", "Date & Time" or "Off". You can only do this when your pictures are set to the "Postcard" mode.
Date stamp on each picture taken
Unfortunately, the Date Stamp feature only works with the "Postcard (1600x1200)" setting. Change the shooting mode to Postcard and you can then turn Date Stamp on/off.
1helpful
3answers
Blurry Pics and not able to set date/time
You can only set the date stamp in the “Post Card” resolution mode. Hit the “function” button, go down to the resolution selection (L, M, S, W, Postcard, etc.). Pick the “Post Card” setting. Hit the “menu” button and the “date stamp” menu will be active
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
