Most probably you will get the rem-re-103011 manual here
SOURCE: i started my reebok ice
First of all check the Fuse in the Motor control board. If it faulty then replace the same. If the fuse again blews the the you have to check the motor and its driver board. Using a car abttery you can check the motor. Connect the red wire from the motor to possitive terminal of the battrey and the black wire to the negative terminal. If the motor is ok the it will run without any trouble. If not then you have to replace the motor. If the motor is working perfectly then you have to check the motor control baord. It is available as modules. If you want to repair the motor control board then, You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will not run or will run at high speed. . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference
ok
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
