Question about 3Com NBX 2102 IP Phone
Are NBX entry Phone Sip compatible?
Are NBX entry Phone Sip compatible ?
Posted by ignacio_hern on
NBX_Tech
    New Friend:
  • 58 Answers
The 2100 series and older aren't SIP compatible. The 3100 series are.
Posted on Jul 27, 2010
What is 3x phone
For 3Com that would mean a 3100 series or 3500 series phones. The 3100 series phones are for NBX and VCX phone systems and the 3500 series phones are for VCX only. Both are also SIP compliant.
Apr 16, 2014 | 3Com Computers & Internet
When there is an operator message like "this number is not in service", NBX phone turns to extension and Audio codes turn to busy tone.
This is a phone company recording and is normal for a call that can't complete. It has nothing to do with the phone system.
Apr 02, 2014 | 3Com NBX 2101 IP Phone
3COM 3100 entry phone, how to configure SIP
From Digium Mailing List:
3Com 3100 series phones do not support SIP with non-3Com systems. They have a basic boot loader which must download code from a 3Com NBX or a 3Com VCX system. If you don't have either of these, then you won't get runtime code on the phone, thereby making it impossible to use the thing with Asterisk.
Asterisk Users 3Com Phones
Mar 14, 2014 | 3Com Computers & Internet
Nbx 2101
You can't. The 1100 and 2100 series 3Com phones aren't SIP phones. Only the 3100 series phones can be used.
May 28, 2012 | 3Com NBX 2102PE IP Phone
What does this message mean: Url call is disabled
This means that your phone will not dial a url number, i.e. sip://[email protected] This is generally a network or configuration error, and I would specifically make sure the phone either has static DNS entries entered or is receiving DNS entries via DHCP.
Mar 01, 2011 | Polycom SoundPoint 650 IP Phone - LCD -...
We have a 3Com NBX V3000. The building our office
This was a rather simple fix. When I was speaking about the NBX V3000, I was talking about our 2U NBX Chassis which holds the line card. When our phone system was installed I wasn't shown the 1U NBX V3000 "Brain". I thought everything was contained in the chassis. Long story, short, I restarted the 1U "Brain" and the system came back up with 5 minutes.
Feb 15, 2010 | 3Com NBX® V3000 (3C10600BUS)
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
Voip841
Yes, If your phone supports SIP then you should be able to program any service provider. On the other hand if this is a Skype only phone then you will not be able to use it with any other service besides Skype because they use a non-standard protocol.
I tried looking up your phone and the closest I came was :
http://www.amazon.com/Philips-VOIP8411B-37-Phone-System/dp/tech-data/B000ND75FW/ref=de_a_smtd
This says in the Tech Specs that it is voip client and softphone compatible (whatever that means). It doesnt say it is SIP compatible. So look up the user manual and if it says that your phone is SIP compatible then you should be able to program any VOIP service provider (90% of them are SIP based) but if all the manual mentions is Skype and nothing else, then you might be out of luck.
Hope that helps!
-AM
Nov 29, 2007 | Philips VOIP8411 IP Phone
Roll back phone software
The phone is in a continuous because it is trying to connect to the NBX. You need to make sure it is on the same network as the NBX. Also, within the NBX you need to make sure Auto-Discovery is enabled. You also need to check how many group 2 licenses you have, as this phone requires one to run on the NBX.
Aug 31, 2007 | 3Com NBX 3102 IP Phone
3Com NBX 2102 IP Phone Logo
243 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Vincent G
Vincent G
Sheldon Dedek
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
