A know very soultion to fix there was no need reprogramme your pc open up your computer and remove the card and reserte the card this mean your card before did not detect hardware for this adapter. It common on Laptops HP Pavnion dv versions in windows 7 operating system. If your experence problems a no very answer renstall your Wireless card so dectects on Windows boot-up and if can't find drivers use Device Manager by going to start control panel system Properties and go to Device manager tab and them when loaded go to other device section and right click update driver and t will search for driver online if fail you need use Driver scanner like Driver Detactive if that fails nothing comes contact you Manifacture see if there drivers for the device or search on Search engine all them will work.
Regards;
Michael
[email protected]
Help needing advice on HP Pavnion dv versions Wireless problem in Windows 7. on install don't dectect wireless devices if no connected or programmed to the system.
You need Service Pack 2 or above to use wireless on XP. I have always hated this problem and feel your frustration.
You will need to either hook your computer up on a wired connection to get the service pack or download it on another computer and transfer it by some type of removable media (CD, floppy).
Service Pack 2 download link:
http://www.microsoft.com/DOWNLOADS/details.aspx?displaylang=en&FamilyID=049c9dbe-3b8e-4f30-8245-9e368d3cdb5a
Check in your "Device Manager" to see if there is a driver problem with the device. If you do see the device in your device manager, right click it and select "uninstall". Then select "scan for hardware changes" under the menu bar. If the option to scan is not there, select something in your device manager list to make it show itself.
It also would not hurt to reinstall the software for the device, along with any drivers for your computer itself. Very easy to overlook installing a certain driver or software.
Also try restarting the computer with the device not plugged into the computer. Then shutting it off, installing the device and turning the computer back on.
There is also the possibility of the device being bad, although I do not think this is your problem. As it sounds, it worked before the reinstall.
Sounds like you need some drivers installed, especially if you just installed XP clean.
Visit support.dell.com, click on Drivers and Downloads, click on the service tag option and enter your service tag located on the bottom.
This will take you to a list of drivers for your specific model. Make sure the OS chosen is Windows XP and in the list you should find some wireless drivers. There may be several different wireless drivers listed. And one of those will be specific to your needs.
You might need to identify which wireless card you have first. Which will requrie gaining access to it to get some part numbers or model numbers from it. There should be an access panel on the bottom that you can open to gain access to the mini-pci wireless card. That way you can see which one you have and download the correct software for it.
I have Service Pack 3, any other suggestions?
