Question about GE Washing Machines
GE washer does not agitate does not stop filling up
Posted by chiefjrs on
Carl Schulzetenberg
  • 1,543 Answers
If your washer is filling until it overflows without agitating, and will stop filling if you turn machine off or interupt power to it, the machine is not seeing that it is full. This may be caused by a blocked water level tube (usually some "goop" where it connects to the tub), a hole in the water level tube (look near the suspension rod or where a mouse may have chewed a hole in it), or a bad water level switch. You do not state a model number, or even if it is a top loading or front loading machine, so that is the most information I am able to provide at this point.
Posted on Oct 19, 2009
5 Related Answers
jumptrout51
steve
  • 3361 Answers
SOURCE: GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
Posted on Apr 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Posted on Apr 25, 2009
Anonymous
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
Anonymous
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Will agitate instead of fill
The pressure switch it broken of the pressure switch is clogged. Please contact me so I can help you.
Jan 02, 2014 | GE GTWP1000MWW Washer
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
GE. Washer MOD. WDSR2080DBWW will not stop
Bad water level sensor or tube connection going to control board.
Sep 06, 2009 | GE WDSR2080D Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
93 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
