1994 Chrysler LHS Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key stuck in the ignition. Position indicator
Shift position indicator shows Park, but steering wheel lock does not engage and shifter (Floor/console) feels sticky (does not move smoothly).
Key will not turn to lock or accessory position
  • Anonymous Mar 15, 2014
    2006 Buick Lucerne floor shifter will not come out of park. Clicking noise I steering and doors lock when I move shifter sideways but will not move down into reverse. Please advise how I can unlock the BTSI or remove console. Thank you.
Trevor Murphy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2014
Trevor Murphy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
800
Points
You need to make sure the shifter is all the way to the left in the Park position.
Anonymous
Level 2:
  • Expert 140 Answers
  • Posted on Oct 19, 2009
Anonymous
Expert
Level 2:
Answers
140
Questions
Helped
33848
Points
245
try turning the wheel to the right/left while turning the key in the ignition. You have to apply some force. Your car is probably outliving its road life.
Cheers & Best Wishes
Need help with ignition switch on 2002 grand prix..keys stays in got it out try it again and sticks in again.
Does the vehicle start an run ?Can you turn the key to the off position ? And the key won't come out ? Did you try some key graphite ( lube ) ? New lock cylinder need maybe . Or is it a problem with
Steering Column Electric Park Lock
If the vehicle is equipped with a floor-mounted console gear shifter, an added safety feature is an steering column electric park lock system in the steering column. The steering column electric park lock system prevents the steering wheel from being locked when the transmission is in gear and the vehicle may be moving. The column ignition lock system consists of a steering column electric park lock and a park position switch, that is located in the A/T shift lock control switch. The steering column electric park lock contains a spring-loaded pin that mechanically prevents the ignition key cylinder from being turned to the Lock position when the transmission is not in the Park position. If vehicle power is lost or the transmission is not in the Park position, the operator will not be able to turn the ignition key to the Lock position and will not be able to remove the ignition key from the column.
2answers
Holden cruze 2009 key stuck in the ignition won't go to off position , can't get it out of park .What is the problem ?
Is it shifter on the floor ?
Ignition Lock Cylinder Control Actuator
If the vehicle is equipped with a floor mounted console gear shifter, it has a ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator's purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in gear and the vehicle may still be moving. The column ignition lock system consists of a ignition lock cylinder control actuator , and a park position switch that is located in the A/T shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded out to mechanically prevent the ignition key cylinder from being turned to the lock position when vehicle transmission is not in the Park position. If vehicle power is lost, and/or the transmission is not in the Park position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
GM had problems with these ! Has a TSB - technical service bulletin !
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
ā€¢ The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
ā€¢ The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will remove voltage from the shift lock solenoid:
- The ignition is in the ON position.
- The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
- The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically locking the shift lever in the PARK position as the solenoid energizes. When the brake pedal is applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid releases the mechanical lock allowing the driver to move the shift lever out of the PARK position. When the transmission is out of the PARK position, the shift lock control solenoid remains de-energized.
During remote start operation, the BCM will energize the shift lock control circuit, locking the shift lever in the PARK position.
Replaced shifter on a cobalt , broken plastic part inside , wouldn't press on micro switch to disengage ! Found replacement shifter at auto slavage yard .$20.00 US
1helpful
1999 Volvo S40 cannot remove key
What make vehicle ? Most all vehicles have a safety system .Don't try an force anything you'll break it !
Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column. They also have this on column mounted shifters !
The Key FOB is stuck in the ignition. How can I get it to eject?
Most if not all vehicles have a Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column. Or it has
Linear Shift Assembly: If the vehicle is equipped with a column mounted gear shift, it has a linear shift assembly on the steering column. The linear shift assembly has a cable that runs from the linear shift assembly to the ignition lock cylinder case. The purpose of this cable is to prevent the ignition key from being turned to the OFF position when the transmission is in gear and the vehicle may still be moving. The linear shift assembly cable contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
Your best bet is to take it to a ASE certified repair shop or the dealer ! The fix involves taking the steering column apart an or the floor shifter assembly ! Also electrical test to determine what is the problem !
Your
Brothers truck a 1987 ford f150, the horn and cruise were not functioning and key was not smooth turning from lock to start. Replaced the key ignition, also had removed steering wheel and blinker assembly...
You should replace all the wires that are in that steering column. Use OEM wire harnesses. There is a clock spring wire in that column that is bad, The shift indicator is a clip on a piece of string that moves when the column turns with the shifter.
1helpful
KEY WON'T TURN ON THE IGNITION
Hi Aldene, Your vehicle seems too young to have a problem with a worn key so I suggest that the problem was related to the position of the steering wheel and the tongue of the locking mechanism. Sometimes when the lock engages it is under the load of the weight of the front wheels, if they are not in the straight ahead position. A small movement of the steering wheel is usually enough to release the steering lock. Regards John
2answers
Ignition stuck key won't turn to start car!
Gear shift is not totally in the park position - had the same problem with a 2011 Acura TL - a rubber band kept the gear shift lever from totally seating in the park position.
Steering wheel locked, shift lever stuck in the park position, neither key will turn the ignition switch
turn ignition key on. now jiggle key gently while simultaneously gently rocking steering wheel. hopefully you will feel a release.
2answers
Key stuck in ignition and cannot get key out
try turning the steering wheel off it's lock. The wheel should turn a tiny bit between stops and if you turn it to the middle it should release the key. If this doesn't wrok mae sure that the transmission gear shift is fully engaged in Park (assuming an automatic transmission)
1helpful
Key stuck in ignition, won't come out.
turn the steering wheel gently side to side as you try and turn the key... sounds like the steering lock has engaged. it can also be a broken ignition switch... not the cyclinder ... the swithc itself
Robert
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
