Question about Olympus EVOLT E-300 Digital Camera
My Evolt E-300 won't take a picture. Seems find until you go to take the pic and then the shutter opens and closes multiple times without any picture.
Posted by erinnmahoney on
Anonymous
  • 797 Answers
Try to set all menu items to default as much as you can. Some cameras have a reset to default setting or a button to reset to default.
After setting to default, try the camera again.
If all fails, this camera will need repairs.
If it is too old, and not worth it, it may be the best to sell for parts on a site such as Ebay.
Posted on Oct 19, 2009
2answers
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
1helpful
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
I purchased this camera months ago and hate it. I guess I dont know how to use it correctly. Any time I try and take pictures it seems like it take forever for the pic to take. By the time it clicks the...
You need to learn the "half-press". You press the shutter button half-way and allow the camera to lock in the focus (it will beep). Then, when the moment is right, you finish pressing the rest of the way for an instant picture.
My camera sees nothing. No pic on the screen. Blank. Has good batteries, I can look at old pictures, but when I want to shoot a new pic, there's nothing on the screen. Its as tho a lens cap was on.
First try pressing the DISP or DISPLAY button on the back of your camera.
If that didn't help, check if your camera is in this list: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a Then see this article.
But if your camera is not listed, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
I have a powershot s3 is and when I turn it on I have no pic. It just started doing this and last time I hit the display button and the pic came up. It will show images of pics that I have already taken....
2answers
1helpful
2answers
Olympus E-300 Digital SLR storing black images.
Most likely the shutter "curtain" (a few pieces looking like sheet metal just behind the mirror, designed to protect the camera CCD from dust and damage due to too much light) is not opening. This will require servicing by Olympus, since you will have to take the camera apart to be able to reach this camera part. Unfortunately, this may be a pretty expensive repair.
1helpful
2answers
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
4answers
Canon powershot a610..pictures come out black..
When you say the shutter is open, you can see the purple glass lens from the front?
Olympus EVOLT E-300 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
