Question about Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
I have the Nordictrack Apex 4100i treadmill. It does not go up and down anymore. You can hear the motor wanting to raise it, but it doesn't move. What do I do? Thank you for your assistance!!
Posted by KarenD01 on
Anonymous
  • 40 Answers
Try caibrating it.
Posted on Nov 01, 2009
My Apex 4100I treadmill tries to start, and I can see barely the belt turning with a sound coming out from the motor, but it stops (very seldom it actually turns and works). Is this by any chance a...
1) YOU HAVE A COMBO PROBLEM: MECHANICAL+ ELECTRICAL*ELECTRONICS
2) ROLLER BEARING DEFECTIVE3)BEARING MOTOR DEFECTIVE.
Electrical:a)main motorb) TRANSFORMERC) COILD) capacitor faulty
electronic:a) main motor controller faulty.
see the block diagram and test according , the main motor board has aprox 90% of functions of any treadmill. Sincerely. Good luck, and G-d bless you.
Jul 31, 2011 | NordicTrack Treadmill
Need new endcap for apex 4100 NTTL#18903
Sorry to inform you, that part is no longer available from the manufacturer.
Feb 26, 2011 | Nordic Track Nordictrack Apex 4100i...
Our Nordic Trac Apex 4100i will power up but the keyboard does not respond to different key presses and the incline is stuck part way up. We ordered a power supply and replaced the original one. That did...
You can try and do a re-calibration on the treadmill (Its listed in the Users Manual) but it sounds like the console has gone bad. To repair this you would have to replace the entire console.
Aug 21, 2010 | Nordic Track Nordictrack Apex 4100i...
Nortrak 4100i wont go up or down
hold down stop and speed + then put safety key on
hit stop once
push incline+
let it go up and down
take key off and reattach
try
if it still doesn't go the incline motor is bad
Aug 07, 2010 | Nordic Track Nordictrack Apex 4100i...
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Own a Nortic Track apex 4100i. Great treadmill.
You need to have the power supply board rebuilt with larger Caps and resistors. Look on the internet under treadmill repairs. The board is easy to replace yourself so don't have someone come in and overcharge you. I think about 4 screws and two plugs.
Feb 10, 2010 | NordicTrack E4000 Treadmill
Where can I get a key to fit the Nordic Tract Apex 4100i
Go to Nordiactrac.com and enter your Model number from the sticker on the frame. It should read NTL or NTTL then 4 or 5 number. Folow the instructions and ask for the Part's List. You should be able to find it there.
Jul 07, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Mar 01, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual Logo
728 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
stargajzer
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
