Question about Garden
INSTALLING NEW FUEL LINESON SX-135? - Garden
Posted by Ronnie Meister on
  • Ronnie Meister
    Ronnie Meister Oct 19, 2009
    CAN OR WHERE CAN I GET A DIAGRAM OR PICTURE OF THIS SOLUTION?
Hal Hallman
  • 770 Answers
There are 3 separate lines. Usually one is a bit smaller than the others. One line goes from the primer bulb to the tank..Usually the small one. Another goes from the tank to the carb...usually an inline filter in this line. There are 2 connections on the carburator...connect to the lower one, if you have 2 different sizes of tubing, this will be the larger of the 2. The 3rd line goes from the primer bulb to the upper carb connection...this is also a small line (if your model has 2 sizes of tubing). Good luck.
Posted on Oct 19, 2009
  • Hal Hallman Oct 19, 2009
    You can purchase the lines, and the bulb from Northern Tool. The assembly comes complete with a diagram in the container.. .Good Luck. You can find the part here,, and also locations near you... and no, I do not work for them.
    http://www.northerntool.com/
    PS If this helps, please provide a rating for me.
Homlite string trimmer sx-135 ut-20609 a ratio gas & oil mixture
You should mix 8 Oz. of two cycle oil to one gallon of gas. I put the oil in first and then the gas and it will be mixed and ready to go.
Jun 08, 2016 | Homelite Garden
Fuel lineson mac3200 chanson saw
Not sure what the question is since you just wrote a statement.
Ethanol gas does ruin these fuel lines. Fuel line can be bought anywhere. ACE hardware fro instance.
Dec 22, 2013 | Garden
Need help reconnecting fuel lines
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Sep 01, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
The trimmer I have is a sx-135 bandit. which fuel line pulls fuel from the tank
The longest of the two lines is the one that pulls the fuel from the tank. It should also have a fuel filter attached to the end of it which lays at the bottom of the tank.
The other line goes form the primer bulb on the carb. to just inside the tank ( about 1/2 in to 1 inch).
Jim
Jun 12, 2009 | Homelite Mighty Lite Lawn Trimmer
My homelite weed eater sx-135 the fuel filter broke of the tube
The longer, and sometimes smaller in diameter fuel line, goes from the carburetor to the bottom of the tank. This line, which has the filter attached to the end, should rest comfortably on the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch, with that very small piece of plastic attached to it. This piece of plastic keeps this line from pulling out of the gas tank. this line serves as an overflow from carb.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite sx 135
Most like course of action:
Overhaul carburetor, new spark plug, flush fuel tank, replace fuel filter and inspect fuel lines.
Apr 11, 2009 | Garden
Need manual for homelite sx-135 weedeater
http://www.homelite.com/service_support/order_parts
Feb 14, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
