Question about JVC AV-32120 32" TV
Picture on my JVC AV 32120 is a little jumpy and has fine horizonal black lines going thru the picture. This happens if I use the cable connection or the RCA plugs connection. If I pound on the top of the set a couple of times it will go away.
Posted by mccord_jason on
Anonymous
  • 647 Answers
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 19, 2009
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
Black Square area on Screen
If you press display on the remote, it will go away. It will come back, it's a common fault for this set and theres a mod to be done to the eeprom.
Apr 24, 2009 | JVC AV-32120 32" TV
Bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | JVC Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Buzzing and static
you have a short in one of your tubes
Dec 07, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-27720 TV Problem: Picture goes to horizonal white line in center.
In most cases the following parts need to be replaced I think the part location numbers are accurate
IC421 LA7832 ( vertical output IC )
Capacitor C424 100UF @35v
Zener Diode D422 MTZJ75-T2
Resistor R541 1.8ohm 2watts
Oct 23, 2008 | JVC AV-27720 27" TV
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
JVC AV 32120
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Sep 27, 2007 | JVC AV-32120 32" TV
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
