Question about Washburn X10 Electric Guitar
I put a Seymour Duncan in my Washburn at the bridge. With volume on ten there is no output. If I back it off to 8, it works fine. Any ideas? It is an HSS with five way switch.
Posted by sgdeshong on
Joe Patch
    Sergeant:
  • 336 Answers
Clean the dirty volume pot with contact cleaner. If any position has no sound at all, other positions work fine then, the potentiometer is dirty.
Posted on Mar 08, 2013
Michial Gueffroy
    President:
  • 1,140 Answers
Here is their site:http://www.seymourduncan.com/ This site might also help:http://www.gmarts.org/index.php?go=230 You may need a different or new volume control.
Posted on Oct 21, 2009
Please....I need a schematic for a guitar with 2 single coil pickups, 2 volume controls, no switches & no tone controls
Go to Seymour Duncan.com for the best listings of guitar schematics. Here's the link-
http://www.seymourduncan.com/wiring-diagrams
I think the one you want is-
Wiring Diagrams
If you don't want the selector switch, just take the wire from each pickup that the diagram shows going to the selector and attach both to the positive leg of the output jack.
Jul 02, 2017 | Music
High E,B,G very little pickup
String alignment and clearance are key... and then matching electronic control designed to work with it.
May 08, 2011 | Seymour Duncan Sph90-1 Phat Cat Bridge...
Hey, I have a Seymour Duncan invader I would like to put in to HSS stratocaster, but the pick-guard has 2 screw-holes where one end of the Pick-up should be screwed in, and the pick-up itself only has one...
Before modifying any guitar of value, verify that the modification materials are compatible and somebody has accomplished it before successfully as the value of the instrument can be severally reduced.
Sometimes one has to use a drill to make extra holes to match...
I would recommend trying the pickup without mounting with screws to test it... Use foam backed double backed tape. This way if it doesn't work the way you want, you haven't torn up anything.
Feb 09, 2011 | Seymour Duncan Sh8 Sh 8 Invader Pickup
Put a seymourduncan in my washburn at bridge. With volume on ten there is no output. If I back it off to eight, it works fine. Any ideas?
Either the pot is wired backwards (easily determined if volume increases in correct direction) OR the pot may be bad. Some defective ones can have a dead spot at the end.
ALSO check for splder splashes casing shorts.
ALSO check that terminals are NOT touching the wood as the BLACK PAINT is conductive and tied to ground.
Oct 19, 2009 | Washburn X10 Electric Guitar
Washburn X10 Electric Guitar Logo
108 people viewed this question
Top Washburn Music Experts
Bruce Showalter
Ron Rak
Ron Rak
David Gust
Are you a Washburn Music Expert? Answer questions, earn points and help others
