Question about IBM ThinkPad X20 2662 Notebook
Excessive noise whenever it is on; kind of a humming
Posted by chueser on
phii
    Scholar:
  • 134 Answers
Either the chip fan has too much dust on it or it might be time to get a new hard drive. You might wanna back up all your important data just in case but get a can of air spray and blow it in the holes closest to the sound.
Posted on Oct 19, 2009
Anonymous
  • 119 Answers
Does it come from your cd-drive? try to empty your cd-drive and observe again
Whenever i try starting my sunfire it makes a humming noise I tried replacing the battery and the starter still nothing Please Help Me
Well first off, where is the noise comming from? I mean is it in the cab, engine area,...or? Next does it only hum when your. Cranking the engine? It.mite the elec fuel pump, Also a frozen solinoid or starter could also be to blame
Mar 16, 2015 | Cars & Trucks
Light problems
what kind of light fixture and lamps are they and what kind of noise is it making. A fluorescent light fixture ballast will make a humming sound. If you buy a more expensive ballast (the humming will stop). However, the ballast cost almost as much as the fixture in most cases.
Sep 04, 2014 | Home
2006 F150 5.4, 4x4, Lariat. Intermittent excessive humming/fan noise from engine compartment
Sounds like the fan clutch bearing is locked up. Running in direct drive will affect MPG drastically. Its a 2006 so its time to replace it. See if the fan blade will spin by hand with the engine off or if excessive wobble is present at the bearing.
Jun 02, 2017 | 2006 Ford F-150 SuperCrew
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have new Samsung 1.5 Ton Window AC ( around one month old). Whenever AC is switched on in FAN or Cool mode the AC (probably FAn motor) make irritating Humming Noise. The noise slightly reduces after...
It is possible that your AC is not getting the right voltage or frequency and hence is trying to scavenge in gettting the current. It will be good if you can check on the mains voltage or on the wiring for a good 15 amp supply line. If there is any reduction or load onthe wire then the voltage can drop considerably. So in the first place kindly check this out. If this seems in order you will have to check for the fan or the compressor motor to be humming. If your cooling seems fine then you can check on the capacitor of the fan or the starter motor. I am sure since this is in warranty you must make a claim to get a free replacement. Hope you find my advice useful Good day
Aug 03, 2010 | Maytag M6Q10F2A Air Conditioner
Drying operation not working.
Kindly notice that are you able to hear any humming noise from the machine if you hear the humming noise means check whether the drum of the machine is moving freely with hands rotation do this after switching off the unit
After doing this if you find that the drum is moving hardly means kindly replace the mechanism
else change the motor of the unit
Jan 20, 2010 | Zanussi WJD1257W Front Load Washer
Model Series MAC2254 hums after heating unit goes off. can turn fan switch off, it quits. what is wrong? audrey
the humming can be the fan itself or restrictions in ductwork. ducts to small will create excess noise.
Dec 10, 2009 | Heating & Cooling
Humming Noise from satellite speakers
noise can be generated since dust in the jack connector of your PC, bad sound card or belive or not, the socket. try to unplug another devices and leave alone the x240... compare.
Apr 02, 2009 | Logitech X-240 Computer Speakers
99 Jeep Grand Cherokee rear end humming
check the differential fluid in the rear differential. if the fluid is low, add fluid and see if the noise is still there, if the fluid level is ok see if the fluid appears metallic, if it is metallic looking or excessively thick it would be a good idea to have the bearings checked out. i am in the process of rebuilding a front differential on a 98 jeep grand cherokee for the same problem. the bearings inside the differential on the carrier and pinion gear were worn out causing a humming noise. if the wear is excessive the gears might also need to be replaced
Feb 17, 2009 | 1996 Jeep Grand Cherokee
IBM ThinkPad X20 2662 Notebook Logo
Top IBM Computers & Internet Experts
Michael Thomas
Michael Thomas
Jax Planet
Jax Planet
efs_perpends
efs_perpends
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
