IBM NetVista M42 PC Desktop Logo
Question about IBM NetVista M42 PC Desktop
Ibm not boot from usb
Ibm netvista not boot from usb
Posted by abubakarbins on
phii
    Scholar:
  • 134 Answers
When the system starts up there is usually a key to hit for SETUP, usually ESC, F1, F4, or DEL
Find it, and hit it at the right time.
You will enter the CMOS or BIOS setup.
Once there, locate the BOOT SEQUENCE section and allow a USB boot or external component Boot to be placed int he sequence it it MIGHT work.
Not sure what you're trying to boot from USB for.
Posted on Oct 19, 2009
Anonymous
    An expert that gotĀ 20 achievements.
    An expert that gotĀ 10 achievements.
  • 687 Answers
Tips:
  1. Recheck the boot order in BIOS (Step 1).The number one reason a bootable flash drive or other USB device won'tboot is because BIOS is not configured to check the USB port first.
  2. Didn't find a "USB Device" boot order listing in BIOS?If your computer was manufactured around 2001 or before, it may nothave this ability. If your computer is newer, check for some other waysthat the USB option might be worded. In some BIOS versions, it's called"Removable Devices" or "External Devices".
  3. Switch to another USB port. The BIOS on some motherboards only check the first few USB ports. Switch to another USB port and restart your computer.
  4. Copy the files to the USB device again.If you created the bootable flash drive or external hard driveyourself, which you probably did, repeat whatever steps you took again.You may have made a mistake before or missed an important file.
Posted on Oct 22, 2009
Anonymous
    Scholar:
  • 109 Answers
Try using USB 1.1 , there is old model USB port unable to sysnchronize the clock with 2.0 USB media
Posted on Oct 21, 2009
5 Related Answers
Anonymous
  • 132 Answers
SOURCE: IBM NetVista boot Prob
Just to add my two cents. The J on the model number stands for Japan--Japanese. The OS install was probably in Japanese also . Here is a link for the BIOS flash. http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4MBUDT
You'll need another computer to work with if yours is down. And remember, when you work in DOS in XP you will need to use the command line. (cmd typed in run) you make this on a diskette then boot the pc with the diskette. It should make the BIOS readable. Then you can change your boot order. You will need a full version OS to put back on. The drivers for this machine are here:http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4S237K#bios
Posted on Nov 06, 2007
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: ibm netvista cannot boot
go to BIOS and change boot sequence.
shut off and try. sometimes there is a hit any key to boot from cd.
Posted on Dec 01, 2007
bpcs
Jim Bruner
  • 112 Answers
SOURCE: after installing windows xp (IBM NetVista )
You will need to install the XP drivers for you model IBM, you can download them from the IBM website find the link to support and driver download. You could use the driver restore disk that came with your IBM "IF" it came with "XP" installed. BPCS
Posted on Dec 30, 2007
iqbal_del
Iqbal Husain
  • 655 Answers
SOURCE: USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Posted on Apr 28, 2008
Anonymous
  • 243 Answers
http://ati.amd.com/support/driver.html
Posted on Aug 16, 2009
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Will try to make a long story short...Attempting to install Windows XP Prof. on a friend's IBM NetVista 6645 Model W2U which he purchased from someplace. It already has XP Prof. installed, but my friend...
Can you get into the BIOS configuration to enable the CD and USB drive?
If so enable these devices.
Check the interior of the desktop to see if the CD drive and USB connectors are still connected.
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Model # IBM NetVista PC Desktop
when you boot hit pause when it gets to the screen just after the memory screen is finished. hit the pause button... it should say which key(s) to hit to enter setup.
Is there a bios password and you can't get past that ?
Robert
IBM Netvista desktop bios problem
First of all if you re formatted the drive You have lost ALL of the information on that drive. Next you don't need to go through BIOS in order to boot from a disk. You can press F8 on the screen that you would normally enter BIOS with.
Hope This Helps
All The Best,
RCF
Lucy,
Thanks
Iqbal
I have netvista 6578rbg, it can boot from the hard disk
Hi lyonson, I gather at one time the drive did function with Vista? IBM has some fix on their web site. Click this link below.
http://www.ibm.com/search/?v=14&en=utf&lang=en&cc=us&hpp=10&catx=Y1zkzPzk6z93z46zP7&q=netvista+6578rbg&cp=&lv=c&cat=k6&x=12&y=10
Even if one of these fix's does not match your exact model no# . Try one that is close. If it does not help call IBM. I assure you it is not your PC but Vista. (There has been & will continue to be more down time with MS's Vista than any other previous version of windows to date). If non of IBM's files listed help you, please call IBM from this link. http://www-304.ibm.com/jct03004c/support/operations/us/en/contracts?cm_re=masthead-_-myibm-_-cs-contracts
I wish I could help more but other suggestions involve erasing the drive & that's not a good idea if you have data on it.
I would appreciate it if IBM solves this issue or one of the firmware’s fix your issue & you post the results. I’d call IBM my self if I had all needed information written on the NetVista PC.
Good Luck!
Mike
After installing windows xp (IBM NetVista )
2answers
Ibm netvista cannot boot
Top IBM Computers & Internet Experts
tonyy168
tonyy168
Level 1 Expert
David Shaub
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
