My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Ok, first take the control panel off, ( panel that has the battery power display etc ) take care in doing to make sure you don't pull any wires off,
first check the wiring on the ignition switch, check the speed pot by moving it up and down,
Check the connections to the battery follow the wires from the battery to the Motor controller, normally marked B+, B-, then follow from the motor controller to the motor again checking the connections.
Make sure the freewheel lever stays in position.
Regards
Gewiz
