Question about Panasonic Computers & Internet
Dew detect yes I drop the camera and now I get dew detect
Posted by visionbenjam on
Anonymous
    New Friend:
WHERE CAN I FIND A BRAIN ANDWIRE HARNESS FOR A VA7077WEUC LCD MONITOR WITH RECEIVER
Posted on Nov 18, 2009
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
May 15, 2010 | Panasonic PV-L750 Camcorder
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Dew Detected message
i have dew detected all the time that shuts down my camera
Dec 11, 2008 | Quasar VM-L459 Camcorder
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Computers & Internet Logo
Top Panasonic Computers & Internet Experts
efs_perpends
efs_perpends
Resolution IT Dubai
Resolution IT Dubai
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
