Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printhead not working - Kodak EASYSHARE 5300 All-In-One InkJet Printer
Posted by ejones7137 on
  • Anonymous Jul 13, 2019
    Start getting paid every month online from home more than $15k just by doing very simple and easy job from home. Last month i have earned $17954 from this online job just by giving this 2 hrs a day using my laptop. I am now a good online earner. Get this job you guys also and start earning money online right now by follow details here......................===>>> www.gocash7.com++
    Don’t copy "++" with web address
Anonymous
I hear this is a common fault with these printers. Kodak are aware of the problem. If you follow the trouble shooting section on the kodak home page you will be given a reference number and be asked to phone their tech support. Tech support will take the ref number and your address and send you a new print head. They do this free of charge. They don't even ask when or where printer was bought. The only info they ask for is the servive number, which you will find when you open the top of the machine.
Posted on Oct 19, 2009
jennifervinget
    Sergeant:
  • 76 Answers
If you are facing any problem in Kodak Printer Dial Kodak Printer Customer Service Number: - 1-833-284-2444
printhead not working - kodak printer support-u1k3banir2jrm20nnm5bi250-1-1.jpg
Posted on Sep 25, 2018
Tip
Printhead won't Print color ink black yellow purple blue red cyan magenta
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipes many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
SDtester.
on Oct 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot get old printhead out does not work would to install the new old
before you removed the printhead out make sure its on the middle of the printer first., remove both ink cartridges., now theres a small tab on the upper left corner of the printhead press that tab then it will remove., and also you can press the tab of of the printhead on the middle upper part portion., those tabs is slightly hidden thats why your cannot see it
Nov 02, 2009 | Kodak ESP 5 Printer
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Prints people purple
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Oct 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My printer wont print black inc and when i want to print color it only prints pink no matter what color i want to print. it is a Kodak easyshare 5100. I just went and bought new inc of the printer to. Any...
I hope this helps.
SDtester.
Kodak easy share5100 will not print,copy from computer properly
Calibration needs to be run if you have not. if you have...
I hope this helps.
SDtester.
Oct 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 All-In-One Printer
I hope this helps.
SDtester.
Sep 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printhead
sure..it can work on occassion, but over the medium to long term, and just when you need it most, voila, it will fail..happens every time...get a new one.
Also, more printer resources are here
Aug 21, 2008 | Canon SmartBase MP390 All-In-One InkJet...
OfficeJet 9130 all-in one
I updated the HP 9130 firmware and encountered the same problem. I turned off the printer, removed all the printheads and the cartridges, closed the printer cover and then turned on the printer again. After seeing an error message on the printer screen concerning the missing printheads, I opened the printer cover, replaced all of the missing printheads and the missing cartridges and then closed the cover. The printer then aligned printheads once as is expected after replacing the printhead and cartridges. Thereafter, it worked normally. I do not know why this procedure worked and if it will work in every case, but for now, it seems to have worked for me.
Apr 10, 2008 | HP OfficeJet 9130 All-In-One Thermal...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
358 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
