Question about Cell Phones
When my phone died I plugged it into the charger and now the lights just flash and when i unplug it and turn it on it immediately say ''Low battery powering off now''
  • 142 Answers
Try the phone on a car charger,could be faulty wall charger or bad battery
Posted on Oct 19, 2009
6ya staff
SOURCE:
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Nokia N900 not turning on or charging
not turning on. red notification light showing
May 14, 2010 | Nokia N900 Smartphone
Pantech C810/Duo Power Problem
YOU MIGHT WANT TO REPLACE THE BATTERY THE LIFE MAY BE GONE CAUSING IT TO NO LONGER CHARGE
Aug 31, 2009 | Pantech Duo Smartphone
My 3200 will only run when plugged into charger, won't charge bat
Try dusting the connector pins on your laptop and connecting the battery back.
Jun 24, 2009 | Averatec 3200 Notebook
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
Motorola Z3 Rizr won't turn on
when you plug in the charger cable to your phone, make sure that you allow it to charge at least 2 hours, if your phone shuts off immediately after this amount of time, you likely need a new battery, they will wear out after a certain number of recharge cycles.. contact your motorola distributer or motorola website to purchase a replacement. Note do not accept "Non-Motorola Batteries or chargers as these are not guaranteed to provide the proper current necessary to safely recharge your battery, if you notice the battery getting Hot, then disconnect the charger immediately and let it cool, before removing and disposing. Remember it is normal for the battery to be warm to touch while charging or the phone itself is in use. but if it gets hot to the touch this is not normal, and the battery needs replaced..
Nov 06, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Wont turn on
my pc no reconoce the driver the usb vx6000
Jun 10, 2008 | LG C2000 Cellular Phone
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
