Admiral LNC6762B washer - water never stops running when starting the cycle..it fills up to a certain point then drains without ever going through the cycle.It happens on every cycle regardless of water temp
Try these one of the following is not operating properly.
Water level sensor is faulty. You can get parts and manual at repairclinic.com
If it's old then the programme dials are worn out if it's still under warrenty then get it repaired if its old then it will cost more to fix than its worth. Sorry no easy fix.
I am only advising from my own experience. I have spent a lot of money on these thing's to repair them. I replaced all the simple thing's.The dial should turn automaticly so when you need to turn it by hand then it's just worn as I explained before. This is only my experience and oppinion. I am a car mecanic but have tried to sort one of these and like yourself. I went to the part's shop and asked what the problem most likely was. I was told it most likely the dial but I could'nt find anything the matter with it and thought they just wanted to sell me a new washer. I then replaced everything I thought would sort the problem and eventually gave in and bought a new one.
My washer was working fine then all the sudden the water runs constantly while it its filling. It goes up so far then drains. It never agitates or spins unless I manually move the dial to that
the last guy said it was the water level sensor. The guy before that said it can't be fixed. I can find no water level sensor on the parts sites. Could it be the water level pressure switch? Repair CLinic has that part.
my washer will fill with water but then skip the next couple cycles and then drain at the last cycle. the timer moves all the way through to the end.
