1997 Chrysler LHS Logo
Alan Ashendorf Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil in 1 1997 chrysler lhs spark plug tube
Oil in 1997 Chrysler LHS Base 6 Cyl 3.5L spark plug tube. Just changed spark plugs and spark plug wires and found cylinder # 3 filled with oil. How do I replace spark tube seal.
Anonymous
Level 2:
  • Expert 301 Answers
  • Posted on Oct 18, 2009
Anonymous
Expert
Level 2:
Answers
301
Questions
0
Helped
174967
Points
959
Although I am not familiar with this particular engine my son's Mazda Miata had oil in the plug holes and it only required a new valve cover gasket to fix it.
How do i change the spark plug seals on a 1996 chrysler lhs
Using a spark plug socket and a long extension, about 12", remove the 1st spark plug. Once the plug is loose, it can be lifted out.
----------------------------obd2express.co.uk
http://www.obd2express.co.uk/wholesale/vcm-metal-box-ids-jlr-new-vcm-release.html
2helpful
Changed plugs and plug wires and now it wont start? i checked for spark off the distributer all 6 were good?
if your engine run before you changed anything,and you are talking about a 3.0 engine,
you have to be careful changing wires on this engine,
you need toonly change one wire at a time,the distributor cap on this engine is just stupid.
if you look under the cap you'll see that a wire on the one side of the cap actually has a contact that leads to the other side of the cap.
cly 5 cyl 6
cyl 3 cyl 4
cyl 1 cyl 2
front of engine
if your looking at distributor cap from front of engine,
two screws hold down cap.
look at the screw closest to the front,from that screw second hole to the left is #1.
firing order is 123456
#2 wire will be at that front screw on cap,keep installing wires counter clockwise.
2001 Chrysler LHS engine misfire
You have a spark plug or wire breaking down under pressure.I would have them changed.
2helpful
2answers
In a 94' Chrysler LHS what is the firing order? Took the plug wires off the housing unit.
1994 Chrysler LHS
3.5 liter SOHC V-6 VIN "F"56539136.gifI HOPE THIS IS WHAT YOU NEED. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. FEEL FREE TO COMMENT ON THE ASSISTANCE
2answers
1994 CHRYSLER LHS. CHANGED PLUGS, CHANGED WIRES,
Try removing air inlet hose at throttle body,and open plate up by turning throttle linkage slightly (engine off) and spray a shot ( second or 2 ) of WD-40 into throttle body, then try to start and see if it try's to start, or starts for a second then dies. If it does, you got a fuel delivery problem. Can you hear fuel pump hum at all in rerar of car when you turn key just to on position? (not start)
3helpful
Location of oil drain plug
Bottom passenger side of oil pan. On the side of the pan. It is a metric bolt and the pan is aluminum, be careful not to strip plug when threading it back in.
Chrysler LHS won't start!!
the starter is on the right side of the motor down below the the air intake bolted to the transmission three bolts and it comes off
2000 chrysler concorde no spark on #2 cylinder
If it ran good prior to spark plug replacement, then yes, I'd be looking real close at the plug wire to that particular spark plug. Perhaps it pulled apart inside boot upon removal. It may even be an indication that they are all getting weak, and time to think about a new set if it's originals.
Good morning. I just need to know all of the tools I will need to change the spark plug wires for a 1997 Chrystler LHS (including tools needed to remove the manifold). Thank you so much.
Torx bit,for cover on the center manifold black cover. 5/8 spark plug socket and rachet and extension bar3/8 drive. Lift out spark plug wires there is a long tube going to plugs.
2answers
Driver side at rear of engine next to oil pan goes into the bell housing.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
