Diplomat Double oven bottom oven fan works but oven does not heat up - whats wrong
I have a diplomat over not heating up, the grill works fine. I have replaced the element and still no luck, could it be the e thermostat. as the oven little red light isn't coming on, on the front panel. the red light only works if I press hard against the panel. any help is welcome thanks.
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems EDiplomat Double oven bottom oven fan works but - 2_bing.gifg src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
