Have made manual adjustment to increase the water flow with not much change at the bubbler. Is there additional work that I can do to increase the the flow? I have siffient flow for supply but what comes out of the bubbler is barely drinkable. Possible a filter or other parts may need to be replaced?
Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
I have a elkay water cooler that has little water flow at the bubbler. I have made necessary manual adjustments but no change. Is there any thing else I can do to increase water flow? Possible changing a filter or other parts?
