We just installed a new version of vista, and we have plugged the headhphones in, and also pressed the power button, so the headphones seem to be working. But when i play music and listen to the headphones, the music doesnt play through the headphones at all, but continues to play through the computer speakers instead.
An expert that got 10 achievements.
An expert that got 5 achievements.
President:
An expert whose answer got voted for 500 times.
Master
Re:
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
If you mean the pale green jack on the back of the monitor, it is not a headphone jack. It is to let you connect the sound output from your computer (usually also a green jack) to a little speaker in the monitor. That speaker is better than nothing, but sound quality is poor.
Yes, you are having driver issues with the applications that are giving you problems. Did you upgrade your media player yourself or automaticly? There is a 64 bit version for vista to install. I expect that the media player is the application hat pandora is riding on top of as well. A suggestion is to remove media player, and download the 64 bit version and install. If you have the 64 bit version now, it might be corrupt or something. Still remove it and get it again. There are services attached to the media player as well that are enhancements such as things for the mixer and equalizer.. these have to be 64 bit compatible as well.. somewhere you have some either corrupted software and enhancements or ones that are not 64 bit capable.. hope that helps you out (look at enhancements first, then pandora, then MSMP)..
thanks!
Stan Skaggs
Have you installed the audio driver?
If you have installed an audio driver, it most likely an incorrect one.
To check if you have installed a correct audio driver.
Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test. If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed. You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work. You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
On the bottom of your laptop there is a sticker from the maker indicating your model version, as there are about five different versions of the Presario 700 series. I need to know what that model version is to get you compatible sound drivers to install or install again. This should fix your problem, and if it doesn't you have a mechanical malfunction in the headphone jack, which when a plug is inserted should disable your speakers.
