Televison & Video Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting sound but no picture when watching dvd and in can't get sound from tv when watching tv
  • mcwaller Oct 18, 2009
    when watching tv getting no sound thru surround sound and when watching dvd getting sound but no picture
Nachiketa Pradhan
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2014
Nachiketa Pradhan
Contributor
Level 1:
Answers
Questions
0
Helped
235
Points
0
1)turn off your dvd
2)press -DISPLAY-TOP MENU-CLEAR-POWER
3)in service mode off your dvd. Then thats it
Ekse
Level 3:
  • Coby Master 13,435 Answers
  • Posted on Oct 18, 2009
Ekse
Coby Master
Level 3:
Answers
13435
Questions
82
Helped
3983081
Points
38023
Your wires are not connected properly seems you have hooked up them in the wrong way.
Anonymous
Level 3:
  • Master 8,619 Answers
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2149161
Points
26471
Hi
Thanks for using FixYa. Make sure the Red and White wire is connected into your TV “AUDIO IN” and the Red and White wire is connected into the L & R. Also check that the DVD player Audio setting Analog Out is set to “2 Channel” and the TV is turned to the correct Video line (AV Input/Video Input 1,2,3.etc). Once your TV is turned to the correct video line, you should see the “COBY” logo and it will work normally. If still the issue persists, then you’ll need to reset the DVD Player for which you’ll need to follow these steps---
Using the DVD player remote control: Open the Tray and press the “PROG” button and then press the “ZOOM” button.
Once the above procedure is performed the tray will be closed which means the DVD player has been reset back to the factory default settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Precision TV - PTV2548 no sound when your watching cable but there is sound forvideo input
may be the source itself(i.e. cable box) also check cables between cable box & TV. If you are connecting the DVD to the same input the cable box is installed, You know that input on the TV is OK. If you get no audio when the DVD is connected to the same input as cable box, then issue is the MAIN PCB.
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
NO sound on TV Picture fine, sound when watching DVD
check your scart male connecter ends are pushed all the way in.
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
No sound or tv signal
Probably need the TUNER either fixed or replaced.
3answers
MAGNAVOX MWC24T5
Do you have a cable box? if so unplug and plug back in the box. I do have issues with boxes doing that, try unplugging the tv also. what have you done to try to fix it?
Can't see full picture on TV
sounds like the dvd players set for differant picture format like full screen compared to wide screen settings. Look in the Menu of the tv as well as the dvd player
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
