SOURCE: DMC FZ20 lens diameter?
You can put on 72mm filters, but you have to use the extension (sorry, but my english is not the best, and i don't know how it is called..)
SOURCE: Replacement rubber moulding for thumb rest on Panasonic DMC-FZ20 ?
Mine fall of too, but fortunatly i found it..
SOURCE: My Panasonic DMC FZ20 won't
With experiences in other cameras I've found a nice, easy way of fixing
things tends to be a "hard reboot" I think it's called. Turn the camera
on, then remove the battery while it's still on causing the camera to
shut down due to power failure. Put the battery back in and IME, all
should be well.
Also, I quote other comments:
"Pretty much the only advice I can give is much the same as summers
above. Take the battery out and run it completely flat using a safe
method like wiring it to a car headlight bulb. Then recharge it
completely.
Having left the camera battery out, put the camera in a plastic bag and
leave it in the fridge overnight to ensure that any capacitance charge
in it drains.
Try again afterwards."
Other posibilitie... your camera has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel. Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Panasonic service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
Hope this helps; send us your comments.
