Question about Lexmark JetPrinter Z55 InkJet
Lexmark z55, 5 paper feed blinks and 2 blinks from the power button, printer does not respond at all, pattern keeps repeating.
Posted by hogan2 on
  • hogan2 Oct 20, 2009
    I have manipulated the strip all I can and it does not alter any blinking. Anything else?
Roopesh S
  • Lexmark Expert
  • 228 Answers
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Posted on Oct 19, 2009
  • Roopesh S
    Roopesh S Oct 20, 2009
    Please turn off the printer and remove the cartridges from the printer an \d turn it on. if the light blinks then the problem is with the printer and if it does not blink then the problem is with any 1 of the cartridges.
Lexmark x2470 won't feed paper
Good day, this is my advise to you. press the power button off and firmly grasp the paper and gently pull it out and press the power button to turn the printer back on. hope it will help you.
have a nice day.
Jul 27, 2010 | Lexmark X2470 All-In-One InkJet Printer
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i9900 on power up after boot, i am getting get 2 flashes on the orange light. I know its related to paper detection. is this a minor or major problem?
Should be minor, just says no paper, load paper and press resume. Sounds like a print job in the buffer or it wants to advance a sheet of paper thru. Paper not feeding could be major though.
Jul 30, 2009 | Office Equipment & Supplies
Paper feed button keeps blinking; documents won't print
which buttons keeps blinking? have you checked your cartridges. you could be out of ink
Jul 13, 2009 | Lexmark Z2420 Printer
My computer says that my printer is offline.
Please follow the steps given below to perform a self test on the printer:
1. Switch off the printer.
2. Press and hold down the paper feed button.
3. While keeping the paper feed button depressed, turn the power back on.
4. When the printer starts to print, release the paper feed button.
5. When the first page is printed, switch off the power (otherwise the printer will keep on printing).
Apr 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Paper jam message, but actually no paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 08, 2009 | Lexmark X2350 All-In-One InkJet Printer
Power buitton blinking and wont stop.
have the same problem. power button keeps on blinking and paper doesnt go in.
Jul 23, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark JetPrinter Z55 InkJet Logo
334 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
