Question about Whirlpool RBS275PD Electric Single Oven
My whirlpool generation 2000+ oven it says f03 what does this mean
Posted by king786 on
Ella Watson
  • 725 Answers
This means you have a bad temperature sensor.
This is a very simple part to replace so you will save a ton of money by replacing this part on your own.
Posted on Oct 21, 2009
rzrfreefr
    Habit-Forming:
    New Friend:
  • 21 Answers
I am confused about this F03 code some says it's a sensor issue other bad control unit ?
Where to test the termistor on control unit ?
http://www.fixya.com/support/t27082170-whirlpool_oven_akz430_goes_f03_mode_in
Posted on Sep 10, 2018
Whirlpool oven fault f03
Hi
Code F03 usually means that the oven temperature sensor is 'open circuit', that is not working at all.
The remedy is to have it replaced.
Dec 19, 2010 | Whirlpool AKZ159IX Oven
Cooker has code f03
Needs programming sometimes they leave the factory without it or they can lose the programme.
Feb 16, 2010 | Whirlpool AKZ159IX Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
789 people viewed this question
Top Whirlpool Ovens Experts
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
