Question about Polaroid PoGo Digital Photo Printer
I got a Pogo a couple of months ago....it worked ok then.I put it away,then yesterday brought it out again.Now it won't work all.The battery is charged up.
Posted by viv_english on
Anonymous
    New Friend:
  • 14 Answers
You may need to feed the blue alignment sheet through the printer again first if you have not used it for a while. you normally get this with a standard 10pk of paper. hope this helps
Posted on Oct 30, 2009
Dashlights and radio flicker and battery light come on
It could be a couple things. Take it to a shop or a place like auto zone and have them test the alternator and the battery, its free :) If they both are testing as good, the next thing would be to check the battery terminals and connections. It simply is not getting the enough charge back to the battery for one reason or another.
Dec 01, 2013 | 1999 Dodge Caravan
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
Change frequency chamberlain
YOU HAD IT IN THE SUN,it is burnt out now
Jul 22, 2013 | Alert Driveway Alarm System
159 battery
ck for electrical short draining the bat. recheck batt could be defect. ck all electrical devices in the car to be sure they' re working. A alarm system is a big drain (if u have one)
Feb 04, 2018 | Cars & Trucks
2001 mercury mountaineer starts fine but sometimes won't start at all
I'm going to first assume that you've checked the battery terminals for gunk build-up. If the electrical system is OK, then the problem likely lies in the gas delivery. You might want to check out the starter anyway. Also, replace the fuel filter and put some Sea Foam or equivalent carb/electric ignition jet cleaner in the gas tank. I might add that your car is 17 years old. Start looking. . .
Jan 18, 2018 | 2001 Mercury Mountaineer
My 2006 gmc Sierra won't start sometimes. I have to recode the key and it starts right up and is fine for a couple of months and then it won't start again and I have to recode again. What could...
Since a recode will fix the problem for a couple of months, I would guess it is how you are carrying or storing your key instead of something in the vehicle. Are you putting them close to your cell phone or other electronic device? If so try to change your habit and store them away from anything electronic (including your alarm clock).
Sep 19, 2011 | 2006 GMC Sierra
Key will not work in ignition. Nothing else works
Its a simple fix....you need to have your lock cylnder in the steering column replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jul 22, 2010 | 2004 Ford Explorer
My cell phone was put into the washer a couple of moths ago?
Once they get wet and sit for a long time, it's not usually worth the time and money to repair them. It's a miracle that it still works at all with that amount of submersion. Good luck!
Mar 12, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Battery ques
Put a voltmeter on the battery. Everything off the battery should be 12.6-12.7 volts or so. A little higher or lower is o.k. Start the bike. Rev up to about 3000 RPM. Voltage should climb and then go to about 14.0-14.5 volts or so. Again a little over or under is O.K. If the voltage doesn't climb above 13 volts or goes over 15 Volt you definitely have charging issues.,,,
Nov 10, 2008 | 2008 Highland Highland Outback
Problems with speakers and microphone on 6515
try plugging the ear bud into the bottom an unplugging it again it worked for me.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Polaroid PoGo Digital Photo Printer Logo
449 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
EmptyBusler
Level 1 Expert
Jim Pattison
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
