Question about Maytag MDB7130 Dishwasher
Seems to have no power but plug has power
Seems to have no power nothing works. But wall plug has power.
  • 189 Answers
Hello- First find power box under unit. Unplug power, open cover and inspect connections. If there is a problem- loose or bad connection-  repair and see if it will run. Let me know if this info helps- have more if needed. Thanks -Ed
Posted on Mar 12, 2010
Anonymous
SOURCE:
I put a new bulb in the tv about 3 months ago. I was watching the tv the other day and turned it off when done. I went to turn it back on the other day and it does nothing, no red, green, yellow blinking...
Try pushing in the reset button on the front panel, its very small and you will need a pin to push it in. Do this while the TV is plugged in, then power it on again see what it does. If still nothing then the FMT board is developing a known fault. You will need to replace the FMT board if reset doesn't work....
Also..
It could be a fan issue, if one of the fans in the TV stop working this will cause the TV not to power up too.
Let me know what you find...
http://tvtechwork.webs.com/
Nov 10, 2010 | Mitsubishi WD-62525 62" Rear Projection...
ZR100 will not trun on
How long have let the camcorder sit still before using again? It seems that you were using it then the battery was out of charge, then you tried to charge it, but nothing happend. Is that your problem?
Jul 25, 2010 | Canon ZR100 Mini DV Digital Camcorder
My 2ooo pixma does not turn on as if there is no electricity. Checked out power supply and it seems to be working.
Canon support says to unplug power cord from back of machine and the wall, and then reconnect. Try another wall plug. Try not using a "power strip".
Nov 28, 2009 | Canon PIXMA iP2000 InkJet Printer
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Apr 10, 2009 | Office Equipment & Supplies
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Maytag MDB7130 Dishwasher Logo
349 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
