Question about Philips DVD728 DVD Player
I am getting a weird screen that is flashing that says "Please enter password"
Posted by mbrassf25 on
william bennett
  • 945 Answers
I cannot find you a manual but common dvd passwords to try are "ooooooooo" or 123456789 adjust to how many spaces there are to fill.
Posted on Oct 18, 2009
What can I do to log into my windows on my laptop?
Which version of Windows is it? If it's windows 10...
  • If you forgot your Microsoft account password, follow these steps.
  • If you don't have a Microsoft account and forgot your local account password, you can't recover it. Instead, you'll need to reset your PC.
  • Note: If you're using Windows 10, version 1803, and added security questions to your local account to help you reset your password, select Reset password on the sign-in screen. (This link appears after you enter an incorrect password.) Then enter the answers to the security questions and choose a new password.
  • Warning: Following these steps will remove all of your data, programs, and settings.
    • Start your PC and select the Power icon in the bottom right-hand corner of the lock screen.
    • While holding down the Shift key, select Restart.
    • On the Boot options menu, select Troubleshoot > Reset this PC > Remove everything.
    • Your PC will restart and will reset itself.
Oct 26, 2018 | Computers & Internet
Tip
Reset Windows 7 Password With Own Created Reset Disk
How to Reset Windows 7 Password
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 | Computers & Internet
Tip
How to reset Windows Vista password?
The question about how to reset Windows Vista password is often seen on various forums and Q&A websites. It is a serious problem for you if you are not good at PC. But if you are familiar with computer, the answer to the question can be very simple. There are many fast and easy ways for you to reset the password. Here it introduce you a simple one - create a Windows Vista password reset disk and use it to help you perform Windows Vista password reset.
Method 1: Reset Windows Vista password through Vista operating system
Windows Vista allows you to create a password reset disk with a USB flash drive in a few seconds. It can help you reset Windows Vista password when you forget it.
Part 1: Create Windows Vista password reset disk
Step 1: Log on your Windows Vista computer.
Step 2: Insert a USB flash drive in computer.
Step 3: Click Start button to select Control Panel.
Step 4: Click User Accounts and Family Safety in the following screen.
Step 5: Click User Accounts when a new screen appears.
Step 6: Click Create a password reset disk in the left pane in the coming up screen.
Step 7: The Forgotten Password Wizard will open, and then click next.
Step 8: Select the portable media drive which you want to create a password reset disk on, and then click next.
Step 9: Enter your current password, and then click next.
Step 10: Click next when the progress indicator shows 100% complete.
Step 11: Click Finish in the next window.
Step 12: You can now remove the flash drive from your computer.
Now you have successfully created a Windows Vista password reset disk. And you'll find a Userkey.PSW file when you open USB flash drive. Keep the file or USB flash drive in a safe place. You'd better to mark the USB flash drive so that you can distinguish it from other USB drives. When you forget password on Windows Vista and cannot log on your PC, you can use the USB password reset disk to reset Windows Vista password. You could follow the below steps.
Part 2: Reset Windows Vista password
Step 1: Start your computer and get to the Windows Vista logon screen.
Step 2: Type a wrong password, and then press Enter.
Step 3: Click OK when the error message that the user name or password is incorrect. And the Reset password link will appear on the Vista logon screen.
Step 4: Click Reset password to open Password Reset Wizard screen.
Step 5: Insert your USB password reset disk in computer.
Step 6: Click Next on the Password Reset Wizard screen.
Step 7: Select your USB password reset disk, click Next.
Step 8: Type and confirm a new Vista password.
Step 9: Input password hint, click Next.
Step 10: Click Finish when you've successfully reset Windows Vista password. You'll return to Windows Vista Logon screen.
Step 11: Enter your new Windows Vista password to log on your Vista machine.
Please Note: You must create the Windows Vista password reset disk before losing your password.
Method 2: Reset Windows Vista password with Windows Login Recovery
If you are locked out of Vista PC without a Windows Vista password reset disk, you'll need Windows Login Recovery to create one. This Windows password recovery software allows you to use a USB flash drive or blank CD/DVD to create a bootable Windows password reset disk. With it, you'll never to be worried when you need to perform Windows Vista password reset. It is also easy for you. Follow the below steps.
Step 1: Download Windows Login Recovery and install it on a computer that you could log on.
Step 2: Burn a bootable CD/DVD or USB flash drive password reset disk.
Step 3: Reset Windows Vista password to be empty.
Step 4: Log on Windows Vista without password.
on Oct 28, 2010 | Computers & Internet
Hp lap top on start up after invent logo comes up with password screen like in doss how do i get past it so windows can start up
ur problem is the bios password that come when ur lap top boots..
so u've to flash ur bios ... as it is difficult(but not impossible) in laptop.. im redirecting to you to this page have full info how to flash ur bios...
http://laptoplogic.com/resources/detail.php?id=78
Feb 13, 2011 | HP Audio Players & Recorders
I keep getting the following message pop up on my laptop: Belkin Router Management belkin.499b's password has been changed. Click to enter the new password. This message flashes on and off every 2 seconds....
Uninstall the belkin router monitor from the control panel ...
it will not happen again
And by uninstalling this ... nothing wrong will happen to the router or the computer
Dec 29, 2010 | Belkin (F5D5231-4) Router
Star talk flash password lost!
to reset the administrator pasword enter feature 985 press 9 at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000.
to enter administrator programming enter feature 983 at the log prompt enter 1020000 and ok
Aug 22, 2009 | NorStar Startalk Flash 2 Phone
Please enter password PHILIPS DVP 3960
enter the default password "136900"
Apr 22, 2009 | Philips DVP3960
Philips DVD728 DVD Player Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
