SOURCE: I have a Gateway M675. I am installing a new hard
Dear,
1 Please install the operating systems in this hardisk
2. Set BIOS to boot from the New System
3. still it fails, there is an issue with boot sector of your hardisk.
SOURCE: Gateway M-6843 laptop does not recognize hard drive.
The ticking sound is known as the "click of death". After a while the bearings in the hard drive get worn down, and the read head has trouble finding the data you want. In this case the drive puts the read head back to "square one" so it can try to trace its steps back to the wanted data. this makes a click noise. Thus the "click of death". Im sorry to say you need a new hard drive, and that your data is likely inaccessible without drastic measures. One method you can try is putting the hard drive in the freezer for 10 minutes. This will stiffen the bearings and may give you a couple of minutes to grab some data. You will want to have your new drive installed and windows loaded on it so you can readily access the data through a usb to sata/ide cable, which you can get on line fairly cheap. Other options are services like OnTrack, who have a team of engineers who open drives and pull the platters and try to get your data, but you are looking at thousands of dollars just for them to try.
SOURCE: my laptop says PXE-E61 : Media
reboot your laptop , read the screenwhen it says press ? for boot menu
press (f8) for bios
press the one that says boot menu and then when it asks you where to boot choose the one that says hard drive. when that boots up and works. you need to restart your pc and press the f8 one to go into bios, then go to the boot tab, and change it to boot 1st from your hdd. somehow it got changed and it is looking somewhere else for the boot directions and its making errors
SOURCE: pxe-e61: media test failure check
Normally, your laptop should be configured to boot up from the hard drive before trying the network boot up. When the hard drive fails or is no longer available, or the boot up sequence in BIOS Setup has been changed so that the network boot is set before the hard drive, the symptom you describe fails.
I would recommend that you do the following:
1. Check BIOS Setup & make sure the boot sequence is set in the correct order (Hard Drive 0 should be before Network Boot).
2. Make sure that the hard drive is seated properly in its slot & that all connections are tight.
3. Make sure that the hard drive powers up when you turn on the laptop.
If none of this helps, then your hard drive has failed.
