If it is black and fairly long it's probably the drive belt and it has likely become stretched (or sticky).The belt fits on the inner circumference of the platter- to re-install - remove the rubber platter cover and platter
-stretch the belt around the inner (botom side inner) lip of the platter
- you should see the motor facing up with a brass capstan or drive bobbin
-from the top side of the platter stretch the belt slightly off the platter through the openings provided and while re-installing the platter loop the belt over the motor bobbin.
If the belt flops off the inner platter it's to stretched and a replacement would have to be ordered
The flapper is secured with a rubber band. The rubber band must be removed from the flapper for the toilet to function properly. Please check the flush valve prior to installation and if the rubber band is present, simply cut it and remove it.
