Garden Logo
Anonymous Posted on Oct 18, 2009
Service manual wheelhorse 31-12K804
Looking for a service manual for a wheel horse. Any suggestions welcome!
Kevin
Level 2:
  • Expert 79 Answers
  • Posted on Oct 18, 2009
Kevin
Expert
Level 2:
Answers
79
Questions
Helped
74912
Points
285
Here is the link to get free manuals from Toro (you'll need the serial number):
https://lookup3.toro.com/request/request.cfm
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Testimonial: "Thanks so much! We've been successful!"
1helpful
2answers
I'm looking for a full-service manual for a 2004 American Iron Horse Texas Chopper
Yes I am looking for a repair manual for a 2003 iron horse 1853cc 107ci the ground pounder outlaw
Feb 20, 2017 • Motorcycles
Tora Lawn Tractor Won't Start . Wheel Horse 13-38 XL
It is not uncommon for a safety switch to get misaligned and not work correctly, also it is not uncommon for a switch not to work even if it is engaged.
You need to check all the switches that must all be properly aligned and engaged in order for the engine to start. As for the light blue wire, I am not sure 100% however typically blue wireds on wheel horse equipment are used in the ignition system. Depending on your model it may be the main ignition power line which runs from the ignition switch (S) connection or (start) connection, then goes to PTO interlock switch, then goes to the Pedal interlock switch, then finally to the starter solenoid. Which sounds like where you have to look because along this blue wire at many points and switches, there is a problem either with a connection (the lose blue wire) or a bad interlock switch along it's way to the starter solenoid. You should also check the PTO interlock switch because it also is connected to a kill relay that will prevent the engine from starting id it is faulty (that light click your hearing, the starter solenoid would be a louder click).
There is a typical ignition service manual available at http://www.mywheelhorse.com/graphics/file/Engines/Engine-Electrical_Service-Manual.pdf It has the typical wireing diagram and all the information you will need presuming you have enough electrical background to use a multimeter.
The website at http://www.scribd.com/doc/47347708/Toro-wheelhorse-Demystification-Electical-wiring-diagrams-for-all-WheelHorse-tractors has diagrams specific for each model but you have to make an account (free) to use the website, and lastly the website http://www.mywheelhorse.com is a invaluable website for anyone who owns a Wheel Horse. Let me know what you figure out!
Nov 12, 2013 • Toro Garden
1helpful
Wheel Horse Manual B115
Go to Google search and type in (Wheel Horse B115 Manual). Search engine will come up with a [PDF] File for Wheel Horse B Series / C Series Tractor. And there is also a service manual link below as well. Both documents can be printed out for your convenience. Hope this helps.
Oct 07, 2013 • Garden
2answers
Need to locate manual for wheel horse 520-HC Garden Tractor, 1988
Go here and put in your Model and serial number of the tag under the seat and you can dowload a Owners Manual. https://lookup3.toro.com/request/request.cfm
Dec 08, 2011 • Garden
2answers
NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Oct 26, 2009 • Garden
5helpful
2answers
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
