Question about Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form - Casio FX-115ES Scientific Calculator
Posted by rah_bhati on
  • ??? ??? ?????? Jun 17, 2013
    can someone help me with same question but in fx-9860 g II sd calculator
k24674
  • Casio Master
  • 8,091 Answers
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
Hope it helps
Posted on Oct 18, 2009
Anonymous
    New Friend:
  • 4 Answers
To convert from rectangular to polar
PRESS [SHIFT and +Pol]
POL(enter the coordinates with a comma between them) =
e.g. [SHIFT and =Pol]
Pol(15,0)=
r=15
0=0
To convert from Polar to Rectangular
PRESS [SHIFT and -Rec] then enter the coordinate and anlge
Hope this helps
Posted on Dec 04, 2009
5 Related Answers
k24674
  • 8091 Answers
SOURCE: canverying polar to rectangular
Here are exemples from the manual.
Posted on Sep 25, 2009
Anonymous
  • 3 Answers
SOURCE: how to change from phasor/polar form to
Hit [Mode] then arrow down until you can choose Rect, then hit [Enter] then [2nd][Quit].
Posted on Sep 01, 2009
k24674
  • 8091 Answers
SOURCE: can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Posted on Nov 15, 2009
Testimonial: "thanx that was very helpful"
  • 102366 Answers
SOURCE: how to change polar form to rectangular form by calculator?
Use the Rec function (shift of the - key).
Rec(r,t) converts a polar value of magnitude r and angle t in the current angular mode. The real value is assigned to X and the imaginary value is assigned to Y.
Use the Pol function (shift of the + key) for the reverse.
It's on page E-37 of the manual. If you've misplaced your manual, you can download a new one from http://www.casio.com/support/manuals
Posted on May 28, 2010
k24674
  • 8091 Answers
SOURCE: i am a casio fx-82MS user. i would like to know
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Posted on Nov 16, 2010
Convert a polar equation to a rectangular equation?
To convert a complex number (not an equation) from rectangular coordinates to polar coordinates you do as follows
2+3[OPTN][ F3 (CLPX)][F1(i)][F6 >][F3> r ,theta][EXE]
Nov 08, 2014 | Casio CFX-9850G Plus Calculator
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
Polar to rectangular conversion working incorrectly
At first, Rect and Polar are a display-format instructions, not a conversion functions. Polar instruction displays complex value in rectangular form a + bi. The complex value can have any complex form. However, an r*exp(i*theta) causes an eror in Degree angle mode according to the TI avowal. See captured images below
Sep 06, 2012 | Texas Instruments TI-84 Plus Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
Conversion of polar to rectangular form and vice versa
Conversion of polar form to rectangular:
  • Switch to CMPLX mode: [MODE] [2]
  • Enter complex number in polar form, e.g. r = 3, θ = 42°: 3 [SHFT] [(-)] 42 [=]
  • Switch to rectangular view: [SHFT] [2] [4]
Conversion of rectangular to polar:
  • Enter complex number in rectangular form, e.g. real part = 2, imag part = 3: 2 [+] 5 [ENG] [=]
  • Switch to polar view: [SHFT] [2] [3]
Jan 12, 2011 | Casio FX991ES Scientific Calculator
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
Hello - i have a casiofx250 calculator and i urgently need to convert from rectanular to polar - how do i do this ? raj
This is an example, plug in your problem.
Convert 12 - 42j to polar form (r ∠ q).
For CASIO calculator...
Keystrokes Display 12 12 rp.gif 12 42 42 plum.gif -42 eq.gif 43.68065934 (= r) xy.gif -74.0546041 (= θ) Therefore,
Complex number in rectangular form: 12 - 42j Same complex number in polar form: 43.7 ∠ -74°
Feb 29, 2008 | Computers & Internet
Casio FX-115ES Scientific Calculator Logo
9,041 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
