Connex 3300 240-Channels Base CB Radio Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you properly set the settings for normal use on the Connex 3300
Anonymous
Level 3:
Guru:
  • Master 773 Answers
  • Posted on Oct 18, 2009
Anonymous
Master
Level 3:
Guru:
Answers
773
Questions
0
Helped
269191
Points
1660
I am guessing that you are talking about getting it to talk on the FCC Citizens band. I am not too firmiliar with connex, but this will work with any radio with expaned channels.
Usually you use a frequency counter to see what frequency you are on when you are playing with the bands.If you do not have a frequency counter you can find the CB this way.
If its in a mobile, or you are not really far from a highway where big rigs travel, you can flip to channel 19 on the channel sellector then flip through the bands checking each time to see if you are on the CB 19. When you start to hear truckers or you get a radio check from a trucker your on CB 19. You can always ask the person, "this is 19 right"?
I recomend geting a frequency counter.
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Connex 3300
sounds like a power amplifier failure. have the rig serviced
2answers
What channels are legal to use on a Connex 3300 with 40 upper, lower and regular settings?
only the CB band to TX on.. you may RX on any frequency.
ch.1-ch.40 am and SSB if it had it.. are the FCC allowed channels. yes there are people on those other bands. user beware.
2answers
Convert connex 3300 fhp to 11 meter
FOR ALL YOU MISS GUIDED FOLKS CONNEX IS NOT PART OF COBRA IN ANY WAY SHAPE OF FORM PERIOD ...CONNEX IS MADE BY RANGER U S A . AS FAR AS THE RECEIVE IT IS PROBABLY ARE MISSED SWITCH OR CONTROL NOT SET RIGHT SIR
Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
1helpful
2answers
How do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
5helpful
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Top Connex Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Patrick Patterson
Patrick Patterson
Level 1 Expert
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
